15 July 2026, 06:41:07
For the past 24 hours: 74 objects added, 70 objects edited, 21 object removed.
MultaRadar SD580, 4.020 км Р12, 50 км/ч
Belarus > Минская область
25 August 2012, 05:51:42
25 August 2012, 15:56:06
Tedos, changed object latitude from 26.663673 to 26.662300
Tedos, changed object longitude from 53.208042 to 53.208505
Tedos, changed object type from  Speed limit sign Speed limit sign to  Portable Camera (trap) Portable Camera (trap).
Tedos, changed speed limit from 50 to 40.
Tedos, changed warning direction type from In a certain direction to Two directions.
Tedos, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Контроль скорости 40 км/ч'.
Tedos, confirmed object added via Mapcam.info program
14 July 2014, 03:35:05
установлена стационарная камера скорости. И знаки ограничения 50 км/ч. Измените точки
14 July 2014, 04:28:11
Tedos, changed object latitude from 26.662300 to 26.662986
Tedos, changed object longitude from 53.208505 to 53.208196
Tedos, changed object type from  Portable Camera (trap) Portable Camera (trap) to  Static speed camera Static speed camera.
Tedos, changed speed limit from 40 to 50.
Tedos, changed object description from 'Контроль скорости 40 км/ч' to 'Контроль скорости 50 км/ч'.
15 July 2014, 15:29:59
mixdm, changed object description from 'Контроль скорости 50 км/ч' to 'Multaradar SD580. Контроль скорости 50 км/ч'.
17 July 2014, 03:01:42
Около Снова мультарадар поставили, если верить http://www.speed-control.by/index.php/by/equipment-by. Кому там ближе, скатайтесь, снимите координаты.
09 January 2017, 18:45:59
YuNew, changed object latitude from 26.662986 to 26.663045
YuNew, changed object longitude from 53.208196 to 53.208257
YuNew, changed warning direction from 124 to 125.
16 August 2018, 19:51:11
YuNew, changed object description from 'Multaradar SD580. Контроль скорости 50 км/ч' to 'MultaRadar SD580, 4.020 км Р12, 50 км/ч'.
YuNew, changed camera model.
26 May 2019, 06:42:58
В какую сторону смотрит объектив камеры?
