29 September 2026, 13:55:43
For the past 24 hours: 54 objects added, 120 objects edited, 24 objects removed.
СКАТ
04 December 2016, 17:42:49
04 December 2016, 17:49:36
valterskott, changed object latitude from 49.312519 to 49.312535
valterskott, changed object longitude from 53.518128 to 53.518195
valterskott, changed object type from  Lane Control Camera Lane Control Camera to  Static speed camera Static speed camera.
valterskott, changed speed limit from 30 to 60.
valterskott, changed warning direction type from Two directions to In a certain direction.
valterskott, changed object notification distance from 500 to 120.
valterskott, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Кречет-С'.
valterskott, confirmed object added via Mapcam.info program
04 December 2016, 17:51:18
04 December 2016, 17:51:56
А вот здесь и ПП может пасти
04 December 2016, 17:53:45
Он и это умеет? Поправьте так, как будет правильно.
04 December 2016, 17:53:34
uDAV163, changed object latitude from 49.312535 to 49.312703
uDAV163, changed object longitude from 53.518195 to 53.518260
uDAV163, changed warning direction from 233 to 234.
uDAV163, changed object notification distance from 120 to 129.
uDAV163, changed object view angle from 15 to 30.
07 May 2019, 08:06:18
joker_san, changed object latitude from 49.312703 to 49.317147
joker_san, changed object longitude from 53.518260 to 53.520336
07 May 2019, 08:07:40
Камеры на прошлом месте нет. Скорее всего её переместили т.к появилось на этом месте.
07 May 2019, 08:14:14
16 May 2019, 11:39:32
16 May 2019, 11:40:08
Или вообще демонтирован, судя по фото
16 May 2019, 11:53:44
Или не к этому месту фото.
16 May 2019, 11:57:12
Точно , на 350 метров ближе.
16 May 2019, 11:39:39
16 May 2019, 12:01:15
УльяновскGSM, changed object notification distance from 129 to 300.
02 October 2021, 07:22:33
02 October 2021, 07:23:14
02 October 2021, 07:23:18
04 July 2022, 06:16:02
30 August 2024, 09:52:40
25 September 2025, 12:29:53
, changed object latitude from 49.317147 to 49.316925
, changed object longitude from 53.520336 to 53.520314
, changed object description from 'Кречет-С' to 'СКАТ'.
25 September 2025, 12:33:07
Поставил на трек.
25 September 2025, 12:30:17
Завышен. Замена камеры -1
25 September 2025, 12:30:20
25 September 2025, 13:03:23
25 September 2025, 13:05:06
Точка действующая , следующую точку по ходу движения предположительно поставили для контроля пешеходного перехода или светофора
