23 October 2026, 17:35:55
For the past 24 hours: 22 objects added, 43 objects edited, 4 objects removed.
Кордон.Про М (тыл)
11 January 2015, 12:23:52
11 January 2015, 12:32:31
Ainstain, changed object longitude from 59.908157 to 59.908181
11 January 2015, 12:48:42
Здесь лучше поставить две однонаправленные точки (по одной для каждого направления).
11 January 2015, 21:26:15
Есть Арены. +1
11 January 2015, 21:28:35
Фото плохого качества, Арены на Питер
12 January 2015, 13:55:54
Ainstain, ставьте вторую точку.
13 January 2015, 12:35:12
Ainstain, changed object longitude from 59.908181 to 59.908144
Ainstain, changed warning direction type from Two directions to In a certain direction.
13 January 2015, 12:49:18
valur111, changed object notification distance from 410 to 600.
valur111, changed object view angle from 30 to 20.
24 March 2015, 21:24:07
март 2015г.
март 2015г.
24 March 2015, 21:29:06
valur111, changed object description from 'Арена' to 'Арены на ферме'.
24 March 2015, 21:29:17
Есть Арены на ферме +1
08 May 2015, 22:17:01
valur111, changed object latitude from 30.995996 to 30.995766
valur111, changed object longitude from 59.908144 to 59.908128
08 May 2015, 22:17:29
Чуть поправил.
05 June 2015, 19:10:57
valur111, changed object latitude from 30.995766 to 30.995491
valur111, changed object longitude from 59.908128 to 59.908130
05 June 2015, 19:11:42
Поставил по MCD (по GPS).
05 June 2015, 23:37:24
01.06.2015г.
01.06.2015г.
05 June 2015, 23:47:02
Дата съёмки: 01.06.2015г.
05 June 2015, 23:48:23
Дата съёмки: 04.06.2015г.
02 November 2015, 14:27:18
      октябрь, 2015г.
      октябрь, 2015г.
25 November 2015, 22:09:14
21.11.2015г.: не работают (РД молчит).
25 November 2015, 22:09:51
Пардон!!!
21.11.2015г.: работают (РД реагирует).
23 February 2016, 19:06:20
На 21.02.2016 камеры сняты, возможно в поверку.
24 April 2016, 19:24:27
Камеры возвращены.23.04.16 в работе
03 November 2016, 15:27:24
[youtube]https://www.youtube.com/watch?v=CrxEhbd0ucE[/youtube]
03 November 2016, 15:28:50
31.10.2016г. - работают все четыре Арены (в обоих направлениях), РД реагирует.
27 February 2017, 19:44:52
23/02/17 камеры в работе.
08 April 2018, 14:36:24
07.04.18г. камеры в работе.
16 May 2018, 23:09:52
22 October 2018, 21:35:31
для мотоцикла не актуально -1
04 January 2019, 14:55:30
Для мотоциклов не актуально! -1
04 January 2019, 17:49:23
В лоб для мото в 0 -1
26 May 2019, 16:49:27
10 August 2019, 12:00:42
sadovodsky, changed speed limit from 90 to 70.
10 August 2019, 12:01:26
10.3 ПДД Вне населенных пунктов разрешается движение: -  другим автобусам, легковым автомобилям при буксировке прицепа, грузовым автомобилям с разр
04 February 2020, 07:41:49
Уже демонтировали камер нет
06 February 2020, 07:01:04
Сам не заметил перевесили на ферму.
06 February 2020, 07:01:35
Хотя радар ее не видит
18 April 2026, 01:40:52
Демортирована
18 April 2026, 02:19:43
Так меняем на Кордон или удаляем?
18 April 2026, 02:20:51
, changed speed limit from 90 to 40.
, changed speed limit from 70 to 40.
, changed object description from 'Арены на ферме' to 'Статическая камера, измеряющая скорость'.
18 April 2026, 02:21:45
Завышен -1
18 April 2026, 02:21:50
Завышен -1
18 April 2026, 05:54:25
, changed object latitude from 30.995491 to 30.992105
, changed object longitude from 59.908130 to 59.908000
, changed object notification distance from 600 to 400.
, changed object description from 'Статическая камера, измеряющая скорость' to 'Кордон.Про М (тыл)'.
18 April 2026, 05:55:23
18 April 2026, 06:01:57
07 September 2026, 09:55:38
сняли -1
07 September 2026, 09:55:48
сняли -1
сняли -1
07 September 2026, 11:50:51
07 September 2026, 11:50:57
07 September 2026, 17:43:34
Удалил,ком выше -1
07 September 2026, 17:43:38
Удалил,ком выше -1
07 September 2026, 17:43:41
Удалил,ком выше -1
