18 July 2026, 17:10:22
For the past 24 hours: 145 objects added, 94 objects edited, 40 objects removed.
Азимут 4 [33км 893м]
23 May 2019, 10:44:59
23 May 2019, 10:45:55
23 May 2019, 10:47:09
По возможности позднее залью фото лучшего качества По виду - Автоураган
23 May 2019, 11:07:06
, changed warning direction from 263 to 260.
, changed object notification distance from 500 to 700.
, changed object view angle from 20 to 55.
25 May 2019, 14:44:10
dron99907, changed object description from 'Статическая камера, измеряющая скорость' to 'АвтоУраган-ВСМ-2'.
dron99907, changed camera model.
26 May 2019, 14:42:44
02 June 2019, 18:20:06
Hyundi505, changed object latitude from 37.125603 to 37.127768
Hyundi505, changed object longitude from 55.787730 to 55.787617
Hyundi505, changed warning direction from 260 to 266.
Hyundi505, changed object view angle from 55 to 50.
02 June 2019, 18:20:21
был недолет
02 June 2019, 18:23:46
Hyundi505, changed object latitude from 37.127768 to 37.128211
Hyundi505, changed object longitude from 55.787617 to 55.787557
07 June 2019, 10:46:47
4
10 June 2019, 04:59:59
Спасибо   в фото
10 June 2019, 04:59:11
Hyundi505, changed object latitude from 37.128211 to 37.127727
Hyundi505, changed object longitude from 55.787557 to 55.787615
10 June 2019, 04:59:32
Еще один замер. Сдвинул на одну опору
25 July 2019, 13:30:52
25 July 2019, 13:36:37
Пинзес... 3 рабочих камеры подряд через каждый километр!
25 July 2019, 13:31:17
штраф +1
25 July 2019, 13:31:23
штраф +1
25 July 2019, 13:33:55
BMW-user, changed object description from 'АвтоУраган-ВСМ-2' to 'АвтоУраган-ВСМ-2 (33км+893м)'.
26 July 2019, 10:59:00
Zenduri, changed object description from 'АвтоУраган-ВСМ-2 (33км+893м)' to 'АвтоУраган-ВСМ-2 (33км 893м)'.
20 August 2019, 08:58:12
Yald, changed object description from 'АвтоУраган-ВСМ-2 (33км 893м)' to 'АвтоУраган-ВСМ-2 [33км 893м]'.
26 August 2019, 07:53:54
активно работает. +1
04 September 2019, 15:20:17
номер датчика сменился AS5000275
03 May 2020, 20:21:11
03 May 2020, 20:21:20
03 May 2020, 20:21:45
24 May 2020, 19:27:35
Начало измерения средней скорости.
24 May 2020, 19:50:27
22 November 2020, 19:00:19
08 April 2021, 08:07:33
04 July 2021, 09:28:15
var998, changed object latitude from 37.127727 to 37.127620
var998, changed object longitude from 55.787615 to 55.787729
var998, changed warning direction from 266 to 265.
var998, changed object notification distance from 700 to 689.
-3
var998, changed object view angle from 50 to 17.
04 July 2021, 15:13:38
Не надо заниматься вредительством сбивая нормальные настройки.
07 July 2021, 12:14:50
Ну, если такие углы нормальные, то ок. Хотел как лучше, получилось как всегда :) Да, и спасибо за карму! Маловато чего-то отминусили. Зануляйте, чего уж там.
07 July 2021, 12:14:51
07 July 2021, 12:14:52
07 July 2021, 12:15:58
Прошу прощения за дубли - глюкануло. Не мой день...
07 July 2021, 16:36:21
Расширенная справка. Скачайте, почитайте "порядок добавления объектов", чтобы понимать, как работает зелёный сектор. ( на изгибах и дорогах с поворотом, не всё однозначно.)
04 July 2021, 15:10:55
maykl3011, changed object latitude from 37.127620 to 37.127727
maykl3011, changed object longitude from 55.787729 to 55.787615
maykl3011, changed object notification distance from 689 to 700.
maykl3011, changed object view angle from 17 to 50.
07 February 2023, 15:05:31
завышен -1
07 February 2023, 15:06:13
kroxan, changed object description from 'АвтоУраган-ВСМ-2 [33км 893м]' to 'Азимут 4 + АвтоУраган-ВСМ-2 [33км 893м]'.
kroxan, changed camera model.
25 April 2023, 16:39:15
007MCD, changed object description from 'Азимут 4 + АвтоУраган-ВСМ-2 [33км 893м]' to 'Азимут 4 [33км 893м]'.
25 April 2023, 16:39:39
До штрафа Азимут -1
25 April 2023, 16:39:43
До штрафа Азимут -1
11 May 2024, 16:38:45
11 May 2024, 16:39:03
11 May 2024, 16:39:06
