19 September 2026, 20:03:39
For the past 24 hours: 146 objects added, 212 objects edited, 34 objects removed.
Азимут 4 [45км 242м]
26 May 2019, 15:07:22
26 May 2019, 15:19:03
fantompg, changed speed limit from 0 to 110.
fantompg, confirmed object added via Mapcam.info program
26 May 2019, 18:32:07
fantompg, changed object latitude from 36.971093 to 36.975282
fantompg, changed object longitude from 55.818650 to 55.818738
fantompg, changed speed limit from 110 to 90.
fantompg, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'АвтоУраган-ВСМ-2'.
27 May 2019, 06:02:45
Ноль -1
27 May 2019, 10:48:17
, changed object latitude from 36.975282 to 36.975241
, changed object longitude from 55.818738 to 55.818643
27 May 2019, 10:48:42
Сдвинул на середину.
10 June 2019, 09:34:28
05 August 2019, 11:33:05
05 August 2019, 11:34:20
fantompg, changed object description from 'АвтоУраган-ВСМ-2' to 'АвтоУраган-ВСМ-2 [45км 242м]'.
07 August 2019, 12:15:38
штраф +1
07 August 2019, 12:15:41
штраф +1
20 August 2019, 05:29:40
20 August 2019, 05:29:47
20 August 2019, 09:01:42
Yald, changed object notification distance from 500 to 700.
20 August 2019, 09:05:27
fantompg, changed object notification distance from 700 to 500.
26 August 2019, 08:04:17
активно работает +1
24 September 2019, 08:32:06
Внимание, похоже немного завышает скорость, на 3-4 км/ч. Во всяком случае при езде по GPS, пришел штраф на превышение 133км/ч
15 July 2021, 08:41:48
Да, завышает на 4-6 км/ч
22 June 2020, 08:43:59
22 June 2020, 08:44:48
Видимо подключили эту камеру к измерению средней скорости до камеры которая на мосту висит, добавьте плиз инфу на карту
13 October 2020, 14:49:17
29 June 2021, 08:31:23
14 April 2022, 08:41:43
14 April 2022, 08:43:15
14 April 2022, 11:05:24
balabol.1974, changed object notification distance from 500 to 700.
13 March 2023, 23:04:17
007MCD, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
007MCD, changed object description from 'АвтоУраган-ВСМ-2 [45км 242м]' to 'Азимут 4 + АвтоУраган-ВСМ-2 [45км 242м]'.
007MCD, changed camera model.
13 May 2023, 17:54:49
07 June 2023, 14:22:10
рейтинг 2 -1
07 June 2023, 14:22:30
007MCD, changed object description from 'Азимут 4 + АвтоУраган-ВСМ-2 [45км 242м]' to 'Азимут 4 [45км 242м]'.
