28 September 2026, 00:40:54
For the past 24 hours: 57 objects added, 51 object edited, 5 objects removed.
КОРДОН-М 4 (в спину) [34км 700м]
24 January 2020, 14:54:36
24 January 2020, 15:09:02
КАЙ, changed speed limit from 50 to 60.
КАЙ, changed speed limit from 0 to 60.
КАЙ, confirmed object added via Mapcam.info program
24 January 2020, 15:21:18
24 January 2020, 15:22:45
Знак при движении из Щёкино в Тулу.
24 January 2020, 15:23:15
24 January 2020, 15:24:17
Знак в направлении из Тулы в Щёкино.
24 January 2020, 15:24:38
24 January 2020, 15:25:19
Камера.
24 January 2020, 15:32:44
КАЙ, changed object latitude from 37.529950 to 37.529970
КАЙ, changed object longitude from 54.049115 to 54.049158
КАЙ, changed warning direction type from Two directions to In a certain direction.
24 January 2020, 15:45:04
КАЙ, changed object latitude from 37.529970 to 37.530010
КАЙ, changed object longitude from 54.049158 to 54.049171
КАЙ, changed object type from  Static speed camera Static speed camera to   .
КАЙ, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Камера, измеряющая скорость (в спину) '.
24 January 2020, 15:50:33
Исправьте, если что не верно.
24 January 2020, 16:09:44
kenalog, changed object notification distance from 500 to 400.
kenalog, changed object description from 'Камера, измеряющая скорость (в спину) ' to 'КОРДОН-М 4 (в спину)'.
24 January 2020, 16:10:44
29 January 2020, 15:02:47
kenalog, changed object description from 'КОРДОН-М 4 (в спину)' to 'КОРДОН-М 4 (в спину) [34км 700м] '.
30 January 2020, 15:13:56
автор, объектив смотрит на Тулу, поменяйте направление
30 January 2020, 15:20:57
КАЙ, changed warning direction from 12 to 193.
КАЙ, changed object notification distance from 400 to 202.
КАЙ, changed object view angle from 15 to 17.
КАЙ, changed object description from 'КОРДОН-М 4 (в спину) [34км 700м] ' to 'КОРДОН-М 4 (в спину) [34км 700м]'.
30 January 2020, 15:25:02
КАЙ, changed object notification distance from 202 to 400.
30 January 2020, 15:27:47
Редактирую с телефона, не совсем точно получается. Подправьте, если что.
30 January 2020, 17:03:48
kenalog, changed object latitude from 37.530010 to 37.529929
kenalog, changed object longitude from 54.049171 to 54.048980
08 July 2020, 16:18:35
kenalog, changed object type from   to   .
28 August 2023, 13:53:13
01 September 2024, 06:48:51
01 September 2024, 06:48:54
01 September 2024, 06:48:56
02 September 2024, 05:26:40
См. выше -1
02 September 2024, 05:26:50
См. выше -1
02 September 2024, 05:27:06
См. выше. Удалил -1
02 September 2024, 05:45:40
, changed object view angle from 17 to 10.
