28 September 2026, 01:11:52
For the past 24 hours: 57 objects added, 51 object edited, 5 objects removed.
Выползово
24 May 2015, 09:51:43
26 May 2015, 04:16:11
SanSanNN13, changed speed limit from 70 to 60.
SanSanNN13, changed warning direction type from Two directions to In a certain direction.
SanSanNN13, changed warning direction from 139 to 325.
SanSanNN13, confirmed object added via Mapcam.info program
26 May 2015, 04:27:42
SanSanNN13, changed object latitude from 36.714591 to 36.714205
SanSanNN13, changed object longitude from 51.503707 to 51.503654
26 May 2015, 05:46:43
deksven_dair, changed object latitude from 36.714205 to 36.714591
deksven_dair, changed object longitude from 51.503654 to 51.503707
deksven_dair, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Выползово'.
26 May 2015, 05:47:01
Поставил на дорогу (OSM)
16 May 2019, 15:07:44
deksven_dair, changed object latitude from 36.714591 to 36.719819
deksven_dair, changed object longitude from 51.503707 to 51.500007
deksven_dair, changed warning direction from 325 to 319.
