05 July 2026, 01:00:23
For the past 24 hours: 122 objects added, 71 object edited, 20 objects removed.
Кречет в спину
24 September 2014, 12:53:25
24 September 2014, 16:17:19
valur111, changed speed limit from 50 to 60.
valur111, changed object notification distance from 500 to 450.
valur111, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Кречет в спину'.
24 September 2014, 16:28:50
Дата съёмки: 24.09.2014г.
11 April 2016, 20:37:58
, changed object type from  Static speed camera Static speed camera to   .
12 April 2016, 06:41:57
Спасибо!))
14 October 2017, 20:20:57
valur111, changed control area.
14 October 2017, 20:21:21
26 October 2017, 10:31:24
leksik-spb, changed control area.
26 October 2017, 10:34:28
Что-то не говорит "Конец участка контроля".
Немного подправил.
02 March 2018, 08:17:40
valur111, changed object notification distance from 450 to 380.
16 May 2018, 22:53:42
26 May 2019, 10:24:32
Интересно, насовсем? Место то совсем нехлебное после установки светофора с одной стороны и, особенно, ЛП с другой.
26 May 2019, 10:24:51
См.выше. -1
26 May 2019, 10:24:54
См.выше. -1
26 May 2019, 14:19:32
см выше, демонтаж, автора нет с конца прошлого года -1
26 May 2019, 14:19:37
26 May 2019, 14:19:39
