18 September 2026, 01:33:35
For the past 24 hours: 83 objects added, 145 objects edited, 33 objects removed.
04 October 2017, 11:45:36
04 October 2017, 11:47:54
ckabter, changed object latitude from 37.638822 to 37.638808
ckabter, changed object longitude from 55.816149 to 55.816362
04 October 2017, 12:22:17
ckabter, changed object notification distance from 500 to 300.
04 October 2017, 14:00:46
05 October 2017, 05:22:47
ckabter, как выглядит камера? Не Вокорд случайно, как здесь?
07 October 2017, 18:26:24
да, здесь повесили Вокорд
08 October 2017, 07:11:42
Указал название, согласно Вашей информации.
05 October 2017, 05:24:31
Ashkrmane, changed object latitude from 37.638808 to 37.638776
Ashkrmane, changed object longitude from 55.816362 to 55.816374
Ashkrmane, changed warning direction from 190 to 187.
Ashkrmane, changed object notification distance from 300 to 500.
06 October 2017, 11:28:07
Ashkrmane, changed object description from 'Новая Камера ' to '???'.
08 October 2017, 07:10:55
, changed object description from '???' to 'Vocord Traffic'.
09 October 2017, 07:09:04
09 October 2017, 07:36:35
Спасибо! +
09 October 2017, 07:09:39
09 October 2017, 07:48:23
+1 Вам к карме за фотоотчет
09 October 2017, 07:36:16
Ashkrmane, changed object latitude from 37.638776 to 37.638910
Ashkrmane, changed object longitude from 55.816374 to 55.817021
10 October 2017, 08:41:30
ИК подсветка уже работает.
19 October 2017, 08:52:44
Как эта хрень должна будет работать? Это камеры средней скорости? На перестроение? Или обычная искра там стоит в диапазоне "К"?
23 October 2017, 19:31:17
читайте здесь
24 October 2017, 19:50:44
korall.vl, changed object view angle from 15 to 20.
03 November 2017, 15:18:27
рабатает +1
05 November 2017, 14:19:52
Фото штрафа есть?
19 December 2017, 19:10:20
Пока не работает. Пришлось нарушать и разметку и превысил скорость. Штрафа нет.
20 December 2017, 05:30:52
Рейтинг "1" -1
01 February 2018, 15:18:23
Ноль до подтверждений. -1
01 February 2018, 15:18:47
01 February 2018, 15:19:35
Авторская карма восстановится через сутки.
19 February 2018, 10:39:16
Комплекс присутствует
04 May 2018, 11:38:53
04 May 2018, 11:39:08
Фоторепортаж
02 June 2018, 04:37:58
Установили автоураган, здесь и на противоложной стороне
02 June 2018, 05:44:01
Спасибо. Как и ожидалось.
02 June 2018, 05:45:02
, changed object description from 'Vocord Traffic' to 'АвтоУраган-ВСМ-2'.
02 June 2018, 05:45:23
02 June 2018, 05:45:49
Замена комплекса. +1
22 June 2018, 10:41:28
22 June 2018, 11:01:05
Спасибо за фото, с кармой 5!
22 July 2018, 02:05:19
И от меня плюс.
29 June 2018, 23:50:58
Пока тишина, ни одного штрафа, чтобы это значило? :)
03 July 2018, 07:03:09
Может их как первую партию АвтоУраганов включат,
сначала висят и не штрафует - народ расслабляется,
а потом становятся рабочими одним днем по всему городу.
21 July 2018, 21:19:47
4
Камера работает, попал на нее сегодня, штраф уже через 6 часов пришел.
21 July 2018, 22:09:11
Поздравляю кармой +5 в качестве утешительного приза :)
22 July 2018, 02:09:19
Ещё плюс. Спасибо! Первый из 14 новых АУ замечен в работе. :)
22 July 2018, 12:54:35
Подтверждено штрафом +1
23 July 2018, 03:44:22
26 July 2018, 05:15:28
Плюс к карме. Спасибо.
25 July 2018, 13:07:38
26 July 2018, 05:13:21
31 July 2018, 12:57:49
Спасибо! Не стали извращаться с типом камеры - просто ВСМ2. Оно наверное и правильно.
28 July 2018, 20:25:35
29 July 2018, 08:49:45
работает +1
29 July 2018, 08:50:08
30 July 2018, 19:33:41
12.9 ч.2
12.9 ч.2
31 July 2018, 13:01:18
Зашёл рассказать, как согрешил здесь числа 12.07 и штраф так не пришёл. Оказывается просто повезло. Всем спасибо за фото и плюсы к карме.
02 August 2018, 05:47:42
02 August 2018, 08:45:49
06 August 2018, 07:25:42
Фото!
15 August 2018, 18:01:31
19 August 2018, 15:50:41
23 August 2018, 06:29:31
23 August 2018, 06:32:57
Работает, еще как))
И штрафы в системе практически "мгновенно".
Мой был через пару часов.
23 August 2018, 06:33:01
12 September 2018, 04:57:03
Для мото неактуально. -1
21 September 2018, 13:02:23
21 September 2018, 15:45:16
21 September 2018, 23:42:22
23 September 2018, 09:04:44
25 September 2018, 12:09:37
Для мото камеры нет. -1
26 September 2018, 18:44:54
"Меня терзают смутные сомнения..."
Уже второй штраф за одну и ту же скорость (85), хотя про камеру помню всегда. Что-то стало напоминать камеру, которая после Северянинской эстакады (idx=1033187)
10 October 2018, 16:12:36
18 October 2018, 09:51:34
20 October 2018, 13:48:22
Ниже задачка для наблюдательных. :)
22 October 2018, 04:33:54
Замена комплекса?!
22 October 2018, 07:35:32
В том-то и дело, что внешне как бы ничего не изменилось. Я и написал - "задачка". Сейчас фото поищу после 10-го числа.
22 October 2018, 07:40:32
22 October 2018, 07:41:04
Кликабельно.
23 October 2018, 12:08:51
Такое ощущение, что фото не отсюда, а, например, с П-опоры, что ближе к центру. Разметка со стрелкой "только прямо" на это намекает.
23 October 2018, 13:32:09
Мне нравится ход Ваших мыслей. Как раз здесь точка расширения разделителя, что на фото. Респект и уважуха!
23 October 2018, 13:39:40
Спасибо за задачку, сразу не въехал ;)
23 October 2018, 13:41:59
Теперь понятен смысл перевеса. :)
20 October 2018, 13:48:33
23 October 2018, 13:33:48
, changed object latitude from 37.638910 to 37.638832
, changed object longitude from 55.817021 to 55.816659
23 October 2018, 13:37:36
Передвинул на 40 метров к П-опоре.
23 October 2018, 14:40:37
Ниже подтверждение монтажа АУ на П-опоре от уважаемого fantompg.
23 October 2018, 14:40:57
24 October 2018, 05:10:40
26 October 2018, 08:58:07
Разметка
Разметка
26 October 2018, 09:10:45
Спасибо, предположения подтвердились.
26 October 2018, 09:11:13
06 November 2018, 07:52:23
12 November 2018, 09:07:26
29 December 2018, 15:01:54
20 January 2019, 20:01:31
26 February 2019, 12:13:26
26 March 2019, 12:24:33
16 April 2019, 16:42:34
16 April 2019, 16:42:44
15 May 2019, 02:43:50
17 May 2019, 12:41:58
Скорость и разметка в комплекте:
17 May 2019, 12:42:08
17 May 2019, 12:42:09
25 May 2019, 20:53:27
25 May 2019, 20:54:52
25 June 2019, 15:52:51
Есть штраф с этой камеры от 16.06.19
25 June 2019, 15:56:00
14 July 2019, 08:21:09
22 August 2019, 09:16:47
27 August 2019, 18:58:29
Наблюдаю второй день на старом месте камеру между щитами со знаками.
30 August 2019, 16:11:16
Вот она
08 September 2019, 09:24:41
там получается одна на первой опоре, а вторая через 25 метров на опоре справа смонтирована
30 August 2019, 17:12:25
08 September 2019, 09:25:08
09 September 2019, 05:52:14
Не вижу никаких изменений с октября 2018.
04 October 2019, 06:23:13
Yald, changed object notification distance from 500 to 350.
04 October 2019, 06:23:59
Уменьшил до предыдущей камеры.
16 October 2019, 23:42:12
17 October 2019, 10:36:20
23 October 2019, 08:48:34
20 November 2019, 23:42:50
09 January 2020, 09:31:33
01 February 2020, 21:04:30
23 March 2020, 02:30:10
30 May 2021, 16:54:30
21 February 2022, 20:58:22
balabol.1974, changed object description from 'АвтоУраган-ВСМ-2' to 'МУЛЯЖ! АвтоУраган (рейтинг ноль)'.
21 February 2022, 20:58:55
выведена из эксплуатации -1
21 February 2022, 20:58:59
22 February 2022, 00:29:12
рейтинг ноль -1
22 February 2022, 00:29:15
рейтинг ноль -1
25 February 2022, 08:10:13
Выше -1
25 February 2022, 08:10:19
Выше -1
07 September 2022, 06:17:26
balabol.1974, changed object latitude from 37.638832 to 37.638822
balabol.1974, changed object longitude from 55.816659 to 55.816627
balabol.1974, changed object view angle from 20 to 25.
balabol.1974, changed object description from 'МУЛЯЖ! АвтоУраган (рейтинг ноль)' to 'АвтоУраган-ВСМ-2 '.
07 September 2022, 06:18:32
замена на новую +1
07 September 2022, 06:18:37
замена на новую +1
07 September 2022, 06:21:55
balabol.1974, changed object notification distance from 350 to 300.
06 February 2023, 20:20:43
06 February 2023, 20:21:11
06 February 2023, 20:21:15
29 June 2024, 11:29:34
демонтаж
29 June 2024, 11:29:39
демонтаж
29 June 2024, 14:20:14
архив -1
29 June 2024, 14:20:18
архив -1
29 June 2024, 14:20:23
архив -1
29 June 2024, 14:21:35
, changed object description from 'АвтоУраган-ВСМ-2 ' to 'архив'.
30 June 2024, 21:16:47
30 June 2024, 21:16:52
