02 November 2026, 01:23:34
For the past 24 hours: 87 objects added, 121 object edited, 49 objects removed.
СКАТ (тыл)
Russian Federation > Новосибирская область
04 May 2016, 08:23:29
04 May 2016, 12:14:26
Камера стационарная
04 May 2016, 12:49:05
А поподробнее. Посмотрите ссылку выше
04 May 2016, 12:14:50
dr.Stax, changed object description from 'Камера' to 'Стационарная Камера'.
16 July 2017, 02:33:18
04 September 2018, 14:54:58
efedorov, changed object latitude from 82.530528 to 82.536278
efedorov, changed object longitude from 55.012056 to 55.011367
04 September 2018, 14:57:45
Камеру перенесли чуть дальше, к повороту на
Камеру перенесли чуть дальше, к повороту на "Марс"
06 November 2018, 22:04:51
22 April 2019, 13:50:53
22 April 2019, 13:51:23
"Арена"
26 May 2019, 16:23:18
kenalog, changed object notification distance from 768 to 600.
kenalog, changed object view angle from 22 to 20.
kenalog, changed object description from 'Стационарная Камера' to 'АРЕНА в боксе'.
18 November 2019, 07:56:13
Yoburger, changed object type from  Static speed camera Static speed camera to  Integrated camera Integrated camera.
16 August 2020, 02:37:11
zubek79, changed warning direction type from In a certain direction to Two directions.
16 August 2020, 02:47:34
Поставили вторую камеру?
16 August 2020, 02:49:25
Нет, её крутят из стороны в сторону. Сейчас смотрит на запад.
16 August 2020, 02:50:14
16 August 2020, 15:15:57
Не ту камеру отредактировал, перепутал. Исправляю.
16 August 2020, 15:15:22
zubek79, changed warning direction type from Two directions to In a certain direction.
zubek79, changed warning direction from 281 to 100.
26 August 2020, 07:08:58
savavovan, changed warning direction from 100 to 282.
savavovan, changed object notification distance from 600 to 453.
22 January 2025, 03:33:26
, changed object type from  Integrated camera Integrated camera to  Static speed camera Static speed camera.
, changed object notification distance from 453 to 400.
, changed object description from 'АРЕНА в боксе' to 'СКАТ (тыл)'.
22 January 2025, 03:36:09
22 January 2025, 03:36:42
Для мото опасна +1
22 January 2025, 15:46:54
Январь 2025
