23 October 2026, 05:46:53
For the past 24 hours: 54 objects added, 89 objects edited, 20 objects removed.
Author Topic: Понижаем рейтинг объекта  (Read 527374 times)
filaret
  • Карма: 18
Re: Понижаем рейтинг объекта
« Reply #660 on: 14 August 2018, 23:42:54 »
https://mapcam.info/speedcam/point.php?idx=173134
https://mapcam.info/speedcam/point.php?idx=502505
Помогите понизить до 0, ящики ещё стоят, но давно не используются.
« Last Edit: 14 August 2018, 23:47:20 by filaret »
  • Карма: 208
« Reply #662 on: 18 August 2018, 05:14:59 »
https://mapcam.info/speedcam/point.php?idx=273354
https://mapcam.info/speedcam/point.php?idx=996437
https://mapcam.info/speedcam/point.php?idx=1028268
нужно понизить до +1 почти год не наблюдается.
Всем спасибо! Сделано.
« Last Edit: 18 August 2018, 14:01:38 by 2maxic »
прохоров
  • Карма: 344
« Reply #663 on: 19 August 2018, 17:11:10 »
Коллеги !
Просьба понизить рейтинг до "-1" (с компенсацией)  следующим камерам в связи с их демонтажом:
https://mapcam.info/speedcam/point.php?idx=889065
https://mapcam.info/speedcam/point.php?idx=889069
https://mapcam.info/speedcam/point.php?idx=974034
https://mapcam.info/speedcam/point.php?idx=974178
https://mapcam.info/speedcam/point.php?idx=974179
https://mapcam.info/speedcam/point.php?idx=889760
https://mapcam.info/speedcam/point.php?idx=889082
https://mapcam.info/speedcam/point.php?idx=889081
https://mapcam.info/speedcam/point.php?idx=978101
https://mapcam.info/speedcam/point.php?idx=888503
https://mapcam.info/speedcam/point.php?idx=873723
https://mapcam.info/speedcam/point.php?idx=882689
https://mapcam.info/speedcam/point.php?idx=882341
https://mapcam.info/speedcam/point.php?idx=867589
https://mapcam.info/speedcam/point.php?idx=974038
https://mapcam.info/speedcam/point.php?idx=881902
https://mapcam.info/speedcam/point.php?idx=881908
https://mapcam.info/speedcam/point.php?idx=857547
https://mapcam.info/speedcam/point.php?idx=880195
https://mapcam.info/speedcam/point.php?idx=978102
https://mapcam.info/speedcam/point.php?idx=880194
https://mapcam.info/speedcam/point.php?idx=880191
https://mapcam.info/speedcam/point.php?idx=880192
https://mapcam.info/speedcam/point.php?idx=917473
https://mapcam.info/speedcam/point.php?idx=978255
https://mapcam.info/speedcam/point.php?idx=917474
https://mapcam.info/speedcam/point.php?idx=880187
https://mapcam.info/speedcam/point.php?idx=880185
https://mapcam.info/speedcam/point.php?idx=974145
https://mapcam.info/speedcam/point.php?idx=880188
https://mapcam.info/speedcam/point.php?idx=881573
https://mapcam.info/speedcam/point.php?idx=963542
https://mapcam.info/speedcam/point.php?idx=881901
https://mapcam.info/speedcam/point.php?idx=857543
https://mapcam.info/speedcam/point.php?idx=881860
https://mapcam.info/speedcam/point.php?idx=876484
https://mapcam.info/speedcam/point.php?idx=889756
https://mapcam.info/speedcam/point.php?idx=874004
terminator090909
  • Дмитрий
« Reply #664 on: 28 August 2018, 16:38:12 »
Помогите понизить дорогу сделали https://mapcam.info/speedcam/point.php?idx=140258
erarner
  • Карма: 7
« Reply #665 on: 10 September 2018, 12:54:20 »
Помогите понизить рейтинг несуществующих лежачих полицейских до -1:
https://www.mapcam.info/speedcam/point.php?idx=146881
https://www.mapcam.info/speedcam/point.php?idx=182974
cheba_101
« Reply #666 on: 11 September 2018, 08:11:26 »
IDX: 934699
Необходимо удалить.
Данная точка не актуальна, асфальт на данном участке обновлен.
bk003@bk.ru
  • Карма: 31
« Reply #667 on: 14 September 2018, 17:26:44 »
Сняли камеру
https://mapcam.info/speedcam/point.php?idx=977329
помогите пожалуйста понизить рейтинг.
Заодно вопрос по карме: раньше понижая рейтинг чужого объекта я автоматически понижал на 1 карму автору, но при желании её можно было легко вернуть. Сейчас рейтингов стало 3. Но я не могу поставить автору 3 плюса (или уже могу?). Как правильно понизить рейтинг объекта не понизив карму автору?
« Reply #668 on: 14 September 2018, 18:12:04 »
Сейчас понижение рейтинга точки не влияет на карму автора точки
Yoburger
  • Карма: 182
« Reply #669 on: 17 September 2018, 03:55:40 »
Нужна помощь в удалении IDX: 104091.
Elen
  • Карма: 335
  • MCD 3.85.1165
« Reply #670 on: 17 September 2018, 04:56:54 »
Удалил.
Dmi3y69
  • Карма: 17
« Reply #671 on: 18 September 2018, 17:24:57 »
https://mapcam.info/speedcam/point.php?idx=1023774
Лежачий полицейский. Может тоже стоит понизить рейтинг пока до 0? В комментариях описание причины.
irmos
  • Карма: 91
« Reply #672 on: 20 September 2018, 09:07:51 »
Просьба понизить рейтинг точек 1066471 и 1066472. Там свежий асфальт, а автор несколько дней не появлялся
Speedcam - Mapcamdroid
Радар-детектор - Sho me g800
erarner
  • Карма: 7
« Reply #673 on: 20 September 2018, 09:17:36 »
готово
dragon772
  • Карма: 132
« Reply #674 on: 21 September 2018, 08:36:25 »
Просьба понизить рейтинг,чтобы точки полностью удалили.
https://mapcam.info/speedcam/point.php?idx=267922
https://mapcam.info/speedcam/point.php?idx=769180
Установлен и работает светодиодный светофор.Теперь удобнее стало со стороны Фряново,поворачивать в сторону Черноголовки и Стромыни.
