04 November 2026, 22:15:29
For the past 24 hours: 73 objects added, 96 objects edited, 17 objects removed.
Author Topic: Hello from Denmark  (Read 4620 times)
patilan
Hello from Denmark
« on: 07 June 2017, 14:46:36 »
I have this App from few days but I think it works normally
I guess I'm doing something wrong (maybe) .
When I drive does not warn me of anything, of any radars or of hidden radars? Would you help me adjust my application and work normally?!
 *HELP*
Thank in advance
Re: Hello from Denmark
« Reply #1 on: 07 June 2017, 15:00:17 »
Where do you use it? There are different sources for speedcams based on country and/or location. Maybe you're using a wrong one or there are no points on the map in your area.
« Reply #2 on: 07 June 2017, 15:00:24 »
Add new, edit old objects and everything is back to normal.
Any member can do it
« Last Edit: 07 June 2017, 15:02:34 by NickF »
yadikiy
  • Карма: 29
« Reply #3 on: 07 June 2017, 15:25:29 »
Hi. Perhaps you the first in Denmark who uses this program. Therefore all in your hands. You should add independently cameras or other dangers on a map if you notice them. Open a map of objects by clicking the link and check whether there is though something on a map in your area.
https://mapcam.info/speedcam/
