22 October 2026, 13:24:20
Астра-Трафик [933км]
03 July 2017, 22:00:10
03 July 2017, 22:00:21
yohan, changed control area.
03 July 2017, 22:06:28
yohan, turned off test mode
03 July 2017, 22:18:26
18 July 2017, 01:27:37
yohan, changed object description from 'Автодория' to 'Автодория [Каспий 933-938км]'.
22 July 2017, 20:54:59
Генбаев, changed control area.
12 October 2017, 17:30:05
12 October 2017, 17:44:25
Timon34, changed object description from 'Автодория [Каспий 933-938км]' to 'Автодория [Р-22 Каспий 934-939км]'.
12 October 2017, 17:44:57
штрафует, актуально +1
14 December 2017, 06:44:59
29 December 2017, 15:20:25
29 December 2017, 15:20:51
14 May 2018, 20:17:37
26 August 2018, 18:38:00
04 October 2018, 18:29:56
Для мото неактуально -1
04 October 2018, 18:35:43
Двухколёсным не актуально -1
04 October 2018, 19:18:17
04 October 2018, 19:18:40
04 October 2018, 19:18:49
Авто +1
25 January 2019, 20:12:02
02 March 2020, 14:04:04
02 March 2020, 14:04:23
см выше, демонтаж -1
02 March 2020, 14:04:25
02 March 2020, 15:16:02
по просьбе, смотреть выше -1
02 March 2020, 15:16:05
02 March 2020, 15:31:37
Ком выше -1
02 March 2020, 15:31:41
Ком выше -1
07 June 2020, 17:20:08
07 June 2020, 17:20:13
07 June 2020, 17:20:18
09 July 2020, 16:47:08
Timon34, changed object latitude from 44.227679 to 44.220877
Timon34, changed object longitude from 48.946764 to 48.954355
Timon34, changed warning direction from 329 to 148.
Timon34, changed object description from 'Автодория [Р-22 Каспий 934-939км]' to 'Астра-Трафик'.
09 July 2020, 16:47:31
Актуализация, установили Астра-Трафик +1
09 July 2020, 16:47:35
09 July 2020, 16:47:42
мото 0 +1
09 July 2020, 16:54:48
09 July 2020, 16:54:51
20 October 2020, 16:59:55
20 October 2020, 17:00:08
20 October 2020, 17:00:13
20 October 2020, 17:01:08
pupok, changed object description from 'Астра-Трафик' to 'Астра-Трафик [933км]'.
05 May 2021, 20:49:37
07 July 2021, 07:10:11
25 July 2021, 12:17:31
14 August 2021, 05:39:09
01 November 2021, 10:14:28
И эту Астру демонтировали. Не понятно, вернут или нет. Штрафы с нее сыпались постоянно
01 November 2021, 16:23:11
12 April 2022, 16:08:01
Появилась информация, что в этом же месте установили Лобачевского (информация требует дополнительной проверки)
18 March 2025, 08:34:00
демонтирована -1
18 March 2025, 08:34:02
демонтирована -1
19 March 2025, 09:41:28
все ранво в тесте -1
19 March 2025, 10:02:38
ну в тесте это то, что есть. А если демонтировали, то надо удалять
19 March 2025, 12:32:58
удалил -1
19 March 2025, 12:33:00
удалил -1
19 March 2025, 12:33:08
обнулил -1
19 March 2025, 12:33:17
, changed object view angle from 15 to 11.
19 March 2025, 12:33:24
, changed object view angle from 11 to 10.
