05 November 2026, 02:17:56
КОРДОН-М 4
10 January 2018, 14:47:38
10 January 2018, 15:58:36
https://mapcam.info/forum/index.php?topic=3025.0 Для идентификации.
10 January 2018, 15:59:38
как придут подробности штрафа - все обновлю.
10 January 2018, 16:03:51
Хорошо.При наличии фото Вам + карме.
17 January 2018, 13:13:29
Комплекс "Кордон-М"
https://ibb.co/h1mVp6
17 January 2018, 13:16:38
в сторону Сергиев посада или в сторону Калязина ехали?
17 January 2018, 13:26:25
17 January 2018, 13:27:06
Так нагляднее. Спасибо за фото. +1 в карму
17 January 2018, 13:17:27
В сторону Посада
17 January 2018, 13:17:28
mafet, changed object latitude from 37.928152 to 37.927627
mafet, changed object longitude from 57.087583 to 57.089247
mafet, changed warning direction from 172 to 171.
mafet, changed object notification distance from 438 to 439.
17 January 2018, 13:18:00
mafet, changed warning direction from 171 to 348.
mafet, changed object notification distance from 439 to 650.
17 January 2018, 13:29:20
silandser, changed object latitude from 37.927627 to 37.927428
silandser, changed object longitude from 57.089247 to 57.089224
silandser, changed object notification distance from 650 to 570.
17 January 2018, 13:30:59
Уменьшил до знака ННП
silandser, changed object description from 'Возможно стационарный радар' to 'Кордон'.
17 January 2018, 13:30:41
Поставил на дорогу по OSM.
Для контроля в спину трансформировал точку с неактуальной засадой
17 January 2018, 13:34:29
Точка в спину https://mapcam.info/speedcam/point.php?idx=124538
18 January 2018, 06:34:47
18 January 2018, 06:45:11
Подтверждено +1
07 February 2018, 05:52:40
07 February 2018, 05:52:47
07 February 2018, 05:53:09
fantompg, changed object description from 'Кордон' to 'КОРДОН-М 4'.
01 March 2018, 00:48:53
В сторону Посада
14 April 2018, 10:13:23
28 May 2018, 18:33:42
25 June 2018, 19:14:06
Камера снята, но крепление осталось. Нужно, наверно, на время обнулить рейтинг
25 June 2018, 19:37:40
07 May 2019, 19:32:56
14 July 2019, 19:47:22
просьба убрать точку, давно её там нет, один столб остался
22 March 2020, 15:54:46
22 March 2020, 15:55:06
Убрали -1
22 March 2020, 15:55:10
Убрали -1
22 March 2020, 15:55:15
Убрали -1
22 March 2020, 15:55:34
Автор не появляется
22 March 2020, 15:58:24
22 March 2020, 15:58:27
22 March 2020, 15:58:31
22 March 2020, 16:02:04
отсутствует -1
22 March 2020, 16:02:07
отсутствует -1
22 March 2020, 16:02:10
отсутствует -1
