22 October 2026, 12:52:37
КОРДОН.ПРО.М (в спину) [13км 540м]
Russian Federation > Кировская область
14 June 2017, 14:07:55
14 June 2017, 14:44:17
shurup21, changed control area.
shurup21, changed warning direction from 301 to 114.
shurup21, changed object notification distance from 590 to 572.
shurup21, changed object view angle from 31 to 14.
14 June 2017, 14:45:27
14 June 2017, 17:06:18
shurup21
Опять вы тут что-то намудрили.
15 June 2017, 06:04:27
я только учусь)..если что извиняйте))
14 June 2017, 17:08:52
Maicl, changed object latitude from 49.598730 to 49.598778
Maicl, changed object longitude from 58.508864 to 58.508931
Maicl, changed control area.
Maicl, changed object type from  Traffic control complex Traffic control complex to   .
Maicl, changed warning direction from 114 to 299.
Maicl, changed object notification distance from 572 to 500.
Maicl, changed object view angle from 14 to 15.
14 June 2017, 17:14:49
Maicl, changed object latitude from 49.598778 to 49.598784
Maicl, changed object longitude from 58.508931 to 58.508951
24 June 2017, 15:35:00
-2
отслеживает в сторону Востока -1
24 June 2017, 15:39:20
Не обоснованное понижение рейтинга +1
29 June 2017, 10:26:09
Объект существует +1
29 June 2017, 10:27:14
Смотрит в другую сторону
29 June 2017, 10:28:57
Зеленый сектор это не туда, куда смотрит камера, а область предупреждения перед ней.
30 June 2017, 20:41:33
тип радара Кордон-Темп (из Постановления от оборотней) 3 штрафа!!!
01 July 2017, 13:29:56
uDAV163, changed object latitude from 49.598784 to 49.598794
uDAV163, changed object longitude from 58.508951 to 58.508923
uDAV163, changed warning direction from 299 to 298.
uDAV163, changed object notification distance from 500 to 300.
01 July 2017, 13:30:07
uDAV163, changed object description from 'Кордон М2' to 'Кордон-М 2'.
01 July 2017, 13:30:25
04 July 2017, 01:33:09
08 July 2017, 00:03:45
08 July 2017, 05:00:21
Сделайте в обе стороны. т.к. камера палит оба направления.
08 July 2017, 05:39:53
aleksandervk
Не возьмет тут Кордон М2 второе направление, слишком широкая разделительная полоса, сканы штрафов это подтверждают.
08 July 2017, 07:03:16
Судя по #MT0104 это Темп на базе блока К2
12 July 2017, 08:02:42
Maicl, changed object latitude from 49.598794 to 49.598070
Maicl, changed object longitude from 58.508923 to 58.509119
Maicl, changed object notification distance from 300 to 500.
Maicl, changed object description from 'Кордон-М 2' to 'Кордон-Темп '.
12 July 2017, 08:04:00
Maicl, changed object latitude from 49.598070 to 49.598320
Maicl, changed object longitude from 58.509119 to 58.509040
20 October 2017, 01:44:53
20 October 2017, 01:44:54
20 October 2017, 01:45:14
03 January 2018, 23:41:05
05 January 2018, 09:53:25
Штрафы +1
05 January 2018, 09:53:44
03 October 2018, 21:15:08
02 August 2018, 08:56:34
штраф пришел +1
11 September 2018, 20:22:21
shurup21, changed object latitude from 49.598320 to 49.600036
shurup21, changed object longitude from 58.509040 to 58.508530
03 October 2018, 21:16:37
setpiton, changed object description from 'Кордон-Темп ' to 'Кордон-Темп (в спину) [14км]'.
22 December 2018, 22:30:18
10 July 2020, 14:45:52
Камеру со столба убрали, похоже насовсем, так как даже провода к столбу все сняты
10 July 2020, 16:04:21
10 July 2020, 16:05:59
А столб однако не убрали... Всяко до нуля надо снижать.
10 July 2020, 16:06:48
См. выше, демонтаж. -1
10 July 2020, 16:06:54
10 July 2020, 16:06:57
10 July 2020, 16:48:02
см выше, демонтаж -1
10 July 2020, 16:48:05
10 July 2020, 16:48:08
10 July 2020, 17:02:14
Смотреть выше -1
10 July 2020, 17:02:17
Смотреть выше -1
10 July 2020, 17:02:19
Смотреть выше -1
10 July 2020, 17:22:48
См.выше.Демонтаж -1
10 July 2020, 17:22:51
См.выше.Демонтаж -1
10 July 2020, 17:22:54
См.выше.Демонтаж -1
11 July 2020, 06:39:53
Выше -1
11 July 2020, 06:39:58
Выше -1
11 July 2020, 06:40:03
Выше -1
14 July 2020, 16:06:33
удалена см выше -1
14 July 2020, 18:52:58
setpiton, changed object notification distance from 500 to 100.
setpiton, changed object view angle from 15 to 10.
14 July 2020, 18:54:14
03 July 2023, 10:22:24
03 July 2023, 10:24:05
Survey_19, changed object latitude from 49.600036 to 49.599970
Survey_19, changed object longitude from 58.508530 to 58.508630
Survey_19, changed control area.
Survey_19, changed speed limit from 90 to 70.
Survey_19, changed object notification distance from 100 to 500.
Survey_19, changed object view angle from 10 to 20.
Survey_19, changed object description from 'Кордон-Темп (в спину) [14км]' to 'КОРДОН.ПРО.М (в спину) [13км 540м]'.
Survey_19, changed camera model.
03 July 2023, 10:24:35
Актуализация +1
03 July 2023, 10:38:51
Актуализация +1
03 July 2023, 10:38:56
Актуализация +1
03 July 2023, 10:43:37
Необходим плюс для актуализации.
03 July 2023, 19:43:30
Актуалтзтровал +1
