22 October 2026, 07:31:24
Multaradar SD 580
Lithuania > Утенский уез
18 August 2013, 04:06:38
21 August 2013, 20:05:01
ErnestoCheGevara, changed speed limit from 50 to 60.
01 May 2017, 15:56:42
Почему 60? В Европе ограничение скорости в населенных пунктах 50! (если нет других знаков, здесь нет)
ErnestoCheGevara, changed object notification distance from 500 to 700.
ErnestoCheGevara, changed object view angle from 15 to 30.
ErnestoCheGevara, confirmed object added via Mapcam.info program
21 August 2013, 20:09:30
ErnestoCheGevara, changed object description from 'Объект добавлен с помощью программы MapcamDroid (off-line)' to 'ТИП МУЛЬТИ-РАДАР'.
21 August 2013, 20:11:03
ErnestoCheGevara, changed object description from 'ТИП МУЛЬТИ-РАДАР' to 'ТИП МУЛЬТИ-РАДАР Скорость 60 км/ч'.
29 August 2013, 09:52:19
ErnestoCheGevara, changed object latitude from 26.053390 to 26.058685
ErnestoCheGevara, changed object longitude from 55.658769 to 55.660691
30 August 2013, 06:45:08
ErnestoCheGevara, changed object description from 'ТИП МУЛЬТИ-РАДАР Скорость 60 км/ч' to ' Multaradar SD 580. Скорость 60 км/ч'.
30 August 2013, 07:08:50
ErnestoCheGevara, changed object description from ' Multaradar SD 580. Скорость 60 км/ч' to 'Multaradar SD 580, Скорость 60км/ч'.
30 August 2013, 23:16:47
ErnestoCheGevara, changed object latitude from 26.058685 to 26.055595
ErnestoCheGevara, changed object longitude from 55.660691 to 55.659510
ErnestoCheGevara, changed warning direction from 57 to 55.
ErnestoCheGevara, changed object view angle from 30 to 15.
20 August 2015, 05:31:30
Т.к. точки 14-го года появились только сейчас - подтверждаю сейчас: радар присутствовал, точка сработала. +1
20 August 2015, 05:31:55
radiorecordperm, changed object latitude from 26.055595 to 26.055573
radiorecordperm, changed object longitude from 55.659510 to 55.659529
01 May 2017, 15:57:22
50 не 60 +1
05 May 2017, 18:16:47
ErnestoCheGevara, changed speed limit from 60 to 50.
05 May 2017, 18:17:24
ErnestoCheGevara, changed object description from 'Multaradar SD 580, Скорость 60км/ч' to 'Multaradar SD 580, Скорость 50км/ч'.
02 June 2017, 11:52:58
работает
02 June 2017, 11:54:09
хотел плюсик поставить так лимит превышен (
14 August 2017, 20:44:49
Ничего страшного )))
23 October 2017, 10:59:23
Нету камеры -1
25 October 2017, 12:34:57
прохоров, changed object latitude from 26.055573 to 26.058738
прохоров, changed object longitude from 55.659529 to 55.660833
прохоров, changed warning direction from 55 to 53.
прохоров, changed object notification distance from 700 to 500.
прохоров, changed object view angle from 15 to 20.
прохоров, changed object description from 'Multaradar SD 580, Скорость 50км/ч' to 'Multaradar SD 580'.
25 October 2017, 12:37:26
Коррекция по информации отсюда
08 November 2017, 10:35:55
Скорасть 50 км/час
08 November 2017, 10:40:50
 Laimuxxx фото вы обещали -  не проезжали еще?
21 January 2022, 18:00:04
20/01/2022 - камеры нет и следов от нее тоже. Перепроверил по видео. Также здесь ее тоже нет: https://gis.eismoinfo.lt/arcgis/apps/View/index.html?appid=4c1702fdbfcc476bbe63ae0d166505a4
21 January 2022, 18:02:13
камера демонтирована и похоже давно и с концами -1
21 January 2022, 18:02:16
21 January 2022, 18:02:18
21 January 2022, 19:02:35
По просьбе -1
21 January 2022, 19:02:50
По просьбеПо просьбе -1
21 January 2022, 19:03:38
По просьбе -1
21 January 2022, 19:15:39
По просьбе на удаление -1
21 January 2022, 19:15:45
21 January 2022, 19:15:50
