25 October 2026, 18:54:14
For the past 24 hours: 50 objects added, 61 object edited, 17 objects removed.
22 April 2019, 16:00:49
22 April 2019, 16:03:26
Замечена сегодня, нужно редактирование,  фото при первой возможности.
22 April 2019, 19:42:20
Принято. И место уточните, плиз. Пока сделаю основные настройки.
22 April 2019, 16:10:38
dim2220, changed control area.
dim2220, changed object view angle from 15 to 19.
22 April 2019, 19:42:47
, changed object description from 'Стрелка плюс в спину' to 'Стрелка-Плюс (тыл)'.
22 April 2019, 19:44:33
, changed warning direction from 325 to 327.
, changed object view angle from 19 to 20.
22 April 2019, 19:45:19
22 April 2019, 19:47:32
, changed object latitude from 37.451391 to 37.451293
, changed object longitude from 55.574919 to 55.574887
22 April 2019, 19:47:50
, changed object view angle from 20 to 25.
22 April 2019, 19:48:31
Сместил на середину дублёра.
22 April 2019, 20:11:55
Она с левой стороны дороги стоит,  по ходу движения.
22 April 2019, 20:40:27
Спасибо. Ставим всегда на середину ПЧ. Согласно Правилам проекта - это аксиома. Теперь за Вами фото, обещали. ;)
23 April 2019, 18:12:20
фото с регистратора
23 April 2019, 19:26:30
Спасибо.
23 April 2019, 18:15:58
dim2220, changed object latitude from 37.451293 to 37.451704
dim2220, changed object longitude from 55.574887 to 55.574620
23 April 2019, 18:17:27
Подвинул немного точку. По яндекс панорамам столб стоит аккурат на линии речки.
23 April 2019, 18:18:04
dim2220, changed object latitude from 37.451704 to 37.451666
dim2220, changed object longitude from 55.574620 to 55.574598
23 April 2019, 18:21:19
23 April 2019, 19:25:32
, changed object latitude from 37.451666 to 37.451715
, changed object longitude from 55.574598 to 55.574625
11 July 2019, 10:00:42
dim2220, changed speed limit from 60 to 70.
11 July 2019, 10:02:22
Ремонт дороги убрали,  сейчас перед камерой знак ограничения скорости 70 км/ч
21 July 2019, 18:46:57
15 September 2019, 11:16:54
Puhlic, changed speed limit from 70 to 60.
15 September 2019, 11:18:38
За несколько столбов до камеры знак - 70. Но! На информационном табло прямо перед камерой горит ограничение 60 на всех полосах.
10 March 2020, 13:26:48
Сегодня ехал на съезде примерно 90, посмотрим
31 July 2020, 10:27:30
до подтверждения -1
11 September 2020, 18:07:23
Смысл делать ноль до подтверждения? Вы можете контролировать штрафы со всех камер Москвы? Камера что, муляж? Где в правилах проекта написано "ноль до подтверждения"?
11 September 2020, 18:52:05
Многие камеры годами не включают!
31 July 2020, 10:27:33
до подтверждения -1
31 July 2020, 10:27:38
до подтверждения -1
11 September 2020, 18:08:29
Объект представляет опасность +1
11 September 2020, 18:08:34
11 September 2020, 18:08:42
11 September 2020, 18:43:18
Данной камеры нет в официальной базе. То есть она не включена. Зачем вы базу камер делаете не актуальной? У Вас есть штраф с данной?
11 September 2020, 22:41:31
Базы официальные – это гибдд.рф? В этом гибдд половины камер в Крыму нет, не доверяю этой базе. По Москве тоже могут быть огрехи.  Заглянем в правила рейтинга объектов. Объект из перечня опасных, подтверждения штрафами нет, ставим рейтинг: 1 - опасные (объект из перечня опасные, без подтверждения штрафов)
11 September 2020, 19:11:30
11 September 2020, 19:16:20
оно конечно что то ещё висит на опоре, но смотрит явно не на дублёр, а на основной ход дороги, в районных новостях нет инфы о штрафах - хотя сарафанное быстро срабатывает где новая камера, за 1,5 года она ни разу не всплыла - но поток машин там большой....осмелюсь предположить что она грузовики контролирует....но и тут тоже тишина, транспортники (общаюсь много) не говорили. На МКАДе и ТТК тоже навешали комплексов и тишина уж скоро как год.
11 September 2020, 19:31:28
нет актуализации, не корректные настройки -1
11 September 2020, 19:31:32
11 September 2020, 19:31:38
30 January 2021, 12:15:14
balabol.1974, changed object type from   to  Other danger Other danger.
30 January 2021, 12:15:28
balabol.1974, changed object type from  Other danger Other danger to   .
18 May 2022, 12:25:21
18 May 2022, 12:25:44
18 May 2022, 12:34:19
abgpro, changed speed limit from 60 to 70.
22 February 2023, 11:29:50
kroxan, changed object description from 'Стрелка-Плюс (тыл)' to 'Стрелка-Плюс (тыл) (рейтинг ноль)'.
13 September 2023, 17:47:49
007MCD, changed control direction from In the back to Counter direction.
007MCD, changed object description from 'Стрелка-Плюс (тыл) (рейтинг ноль)' to 'МУЛЯЖ! Стрелка-Плюс (рейтинг ноль)'.
06 September 2024, 16:29:49
06 September 2024, 16:29:52
06 September 2024, 16:29:56
06 September 2024, 16:30:32
, changed object description from 'МУЛЯЖ! Стрелка-Плюс (рейтинг ноль)' to 'архив'.
