21 November 2026, 19:32:30
For the past 24 hours: 46 objects added, 58 objects edited, 4 objects removed.
СКАТ [969км 400м]
19 November 2019, 17:09:53
19 November 2019, 17:11:58
2maxic, changed object latitude from 40.217489 to 40.217535
2maxic, changed object longitude from 47.974419 to 47.972937
2maxic, changed speed limit from 80 to 90.
2maxic, changed speed limit from 0 to 70.
2maxic, changed warning direction type from Two directions to In a certain direction.
2maxic, changed warning direction from 358 to 1.
2maxic, changed object notification distance from 500 to 600.
2maxic, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Мобильная засада (контроль скорости)'.
2maxic, confirmed object added via Mapcam.info program
19 November 2019, 17:12:55
14 June 2020, 21:09:41
УльяновскGSM, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to  Static speed camera Static speed camera.
УльяновскGSM, changed object description from 'Мобильная засада (контроль скорости)' to 'СКАТ [969км 400м]'.
14 June 2020, 21:09:58
УльяновскGSM, changed object latitude from 40.217535 to 40.217530
УльяновскGSM, changed object longitude from 47.972937 to 47.972827
15 June 2020, 00:16:06
11 August 2020, 15:35:34
Сюда ли?
11 August 2020, 17:11:13
Смотрите дату на штрафе и ссылку выше.
11 August 2020, 15:35:19
03 December 2021, 13:27:58
24 July 2022, 20:13:42
С  -середины июня 06.2022 по настоящее время 24.07.2022 данный СКАТ снят, остался только кронштейн от него.
24 July 2022, 20:14:08
25 July 2022, 03:24:23
2maxic, switched object to test mode
25 July 2022, 17:46:56
До возвращения камеры -1
25 July 2022, 17:46:59
30 July 2022, 20:55:46
Камеры нет -1
30 July 2022, 20:55:56
30 July 2022, 20:56:58
Второй месяц данный СКАТ как снят, камеры нет.
31 July 2022, 07:12:23
Камера на поверке бывает до 6 месяцев, так что я думаю, удалять все-таки не стоит в этот период.
31 July 2022, 22:43:03
Езжу часто через это место, почти каждую неделю, как скат появится отпишусь, если не опередят)
03 August 2022, 13:03:52
03.08 все еще отсутствует
09 August 2022, 13:22:24
Не подтверждено 09.08 еще не повесили, если вообще повесят
12 August 2022, 17:23:44
Интересно, за что это -1 к карме дали?  За то, что переодически здесь проезжаю и контролирую вернулся СКАТ или нет? Красавцы, ребята, слов нет
13 August 2022, 18:41:48
То, что Вы ездите здесь регулярно, это хорошо. Но полезным будет информация о появлении камеры, а не о её отсутствии при каждом Вашем проезде мимо. Точка сейчас имеет рейтинг, который не загружает её в базу. Предупреждений нет, ложной сработки не будет. Как только камера появится, сразу сообщите, а если этого не произойдёт, точка будет удалена системой через несколько месяцев.
13 August 2022, 20:20:33
Так может быть комментарии для того и созданы, чтобы комментировать точку и держать в курсе о её состоянии?  Полезным может быть не только инфа о её наличии, но и о её отсутствии, т.к. 90% данный СКАТ просто на поверке, т.к. остальные СКАТы установленные в период вместе с этим на данном участке  -50км не доментировали, а остались рабочими.
13 August 2022, 20:21:01
И было странно и непонятно обидно за это, что кто-то так подсобил мне
16 August 2022, 17:22:57
Комментировать нерабочую точку не имеет смысла.
28 August 2022, 15:27:05
Поставили, активен, рабочий
28 August 2022, 15:27:12
28 August 2022, 16:29:27
Камеру вернули. +1
28 August 2022, 16:29:52
Камеру вернули. +1
28 August 2022, 16:29:57
Камеру вернули. +1
28 August 2022, 16:30:25
Вренул +1
28 August 2022, 16:31:21
29 August 2022, 07:56:15
2maxic, turned off test mode
09 April 2026, 17:39:40
по состоянию на 01.2026-04.2026, ремонт дороги, камеры нет
01 November 2026, 15:59:52
01 November 2026, 15:59:54
01 November 2026, 16:33:08
Отсутствует -1
01 November 2026, 16:33:10
Отсутствует -1
01 November 2026, 16:33:12
Отсутствует -1
01 November 2026, 16:33:32
02 November 2026, 13:03:00
