17 October 2026, 22:33:02
For the past 24 hours: 71 object added, 32 objects edited, 5 objects removed.
Стрелка-Плюс (тыл)
25 June 2019, 08:40:57
25 June 2019, 08:41:55
В спину, с телефона не получается сделать. Фото чуть позже.
25 June 2019, 08:57:36
Gindos33, changed object latitude from 37.450443 to 37.451121
Gindos33, changed object longitude from 55.670554 to 55.670783
Gindos33, changed control area.
Gindos33, changed object type from  Lane Control Camera Lane Control Camera to   .
Gindos33, changed object description from 'Полоса и разметка' to 'Полоса и разметка в спину'.
Gindos33, changed additional information (RU): \"
25 June 2019, 08:57:57
25 June 2019, 09:00:05
25 June 2019, 09:41:07
, changed object latitude from 37.451121 to 37.451754
, changed object longitude from 55.670783 to 55.670982
, changed object type from   to  Lane Control Camera Lane Control Camera.
, changed warning direction from 242 to 241.
, changed object notification distance from 280 to 350.
, changed object view angle from 45 to 30.
, changed object description from 'Полоса и разметка в спину' to 'Стрелка-СТ (тыл)'.
25 June 2019, 09:42:09
25 June 2019, 09:42:59
25 June 2019, 09:44:01
25 June 2019, 10:54:49
Yald, changed object type from   to  Lane Control Camera Lane Control Camera.
25 June 2019, 10:56:00
Камера смещена в конец участка контроля. Тип "В спину" будет вводить в заблуждение.
28 June 2019, 09:08:42
22 October 2019, 09:16:15
22 October 2019, 09:16:55
Камера фиксирует в спину полосу, проезд на красный и поворот направо без стрелки
22 October 2019, 09:52:32
Рейтинг поднимите плиз.
22 October 2019, 09:53:00
Рейтинг точки в смысле, раз заработала.
22 October 2019, 10:06:02
22 October 2019, 10:06:06
22 October 2019, 10:06:09
22 October 2019, 10:07:25
22 October 2019, 10:10:49
Фото штрафа +1
22 October 2019, 10:10:54
Фото штрафа +1
22 October 2019, 10:10:58
Фото штрафа +1
30 October 2019, 11:29:54
30 October 2019, 11:30:43
сцуко
04 November 2019, 14:14:49
04 November 2019, 14:15:14
12.12.1 - Проезд на запрещ. сигнал светофора или запрещ. сигнал регулировщика
04 November 2019, 20:32:57
04 November 2019, 20:33:55
Поворачиваешь на мигающую "стрелку" и вот оно фото.
11 November 2019, 20:30:57
                12.12.3 - Повторный проезд на запрещ.сигнал светофора (регулировщика)
11 November 2019, 21:17:05
Какая популярная камера, прям не ожидал, думал очередная бестолковая установка.
22 November 2019, 06:24:26
22 November 2019, 06:24:55
Рядность
22 November 2019, 06:25:15
08 December 2019, 21:25:03
Парни. Я нифига не пойму) Её кого-нибудь добавит) В упор не вижу её на карте)
26 March 2020, 09:52:23
Кого её? ))
08 December 2019, 21:25:05
08 December 2019, 21:26:05
Имелось Кто-нибудь.
08 December 2019, 21:26:08
Имелось Кто-нибудь.
05 December 2019, 14:13:13
Пришел штраф,за проезд на красный на мигающую стрелку.
09 December 2019, 10:41:31
30 January 2020, 07:50:35
30 January 2020, 07:51:01
Поворот направо после того, как погасла стрелка.
05 February 2020, 23:38:20
12.12.2 - Неостановка перед стоп-линией
03 March 2020, 21:37:20
17 June 2020, 09:54:09
Gheka, changed object type from  Lane Control Camera Lane Control Camera to  Traffic control complex Traffic control complex.
17 June 2020, 20:01:22
На каком основании? Есть пример штрафа за превышение скоростного режима?
18 June 2020, 05:37:24
https://mapcam.info/forum/index.php?topic=5685.90 Причем тут полоса движения, если штрафы приходят (лично мне пришел недавно) и за запрещающий сигнал светофора. Как раз данное обозначение и приводит к штрафам (у кого не проговаривается доп инфа), т.к. камера контроля полосы движения уж точно не подразумевает контроль проезда на красный.
18 June 2020, 09:02:22
Именно таким образом настроены все подобные объекты на проекте. Информация о виде контроля есть в TTS (Разметка. Рядность. Стоп-линия. Красный).
17 June 2020, 20:01:40
Yald, changed object type from  Traffic control complex Traffic control complex to  Lane Control Camera Lane Control Camera.
05 August 2020, 15:56:25
05 August 2020, 15:57:40
Штраф за красный свет.
19 April 2021, 08:15:28
При чём тут Мичуринский 27 к2? Это ж совсем в другом месте.
19 April 2021, 08:33:39
Привязка идет к ближайшему дому.
19 April 2021, 20:18:59
Мичуринский 27 к2 возле м. Раменки, совсем не ближайший.
19 April 2021, 20:37:41
Внимательней прочитайте, что написано "д27, к2, по ул. Нукулинская" А нарушение само на Мичуринском проспекте, но из ближайших домов, дом на Никулинской, к нему и привязка.
19 April 2021, 21:16:16
Спасибо. Действительно на фото есть Никулинская, а в графе "Место нарушения" упоминания Никулинской нет, это и смутило. На днях прилетел штраф, смотрю и не понимаю. На госуслугах однозначно показывает на карте Мичуринский 27 к2., фотографии не подгружаются. Решил разобраться.
04 October 2020, 14:43:09
За проезд перекрестка в прямом направлении на желтый штраф не пришел. Время события - август 2020 г.
11 August 2021, 18:42:36
balabol.1974, changed object description from 'Стрелка-СТ (тыл)' to 'Стрелка-Плюс (тыл)'.
11 August 2021, 18:42:59
замена до подтверждения -1
11 August 2021, 18:43:02
11 August 2021, 18:43:05
16 August 2021, 10:24:25
03 January 2022, 14:24:00
03 January 2022, 14:25:35
19 January 2022, 17:50:33
Здравствуйте всем!!! С прошедшими праздниками и наступившим Крещением! Подскажите плиз,почему при оповещении она не договаривает "в спину"?
19 January 2022, 17:57:33
На ТСС это не прописано, сама точка значится как "тыл", то есть в самом начале "Контроль полосы в спину" должно говориться.
20 January 2022, 14:05:22
balabol.1974, changed object latitude from 37.451754 to 37.451092
balabol.1974, changed object longitude from 55.670982 to 55.670793
balabol.1974, changed object notification distance from 350 to 300.
21 January 2022, 14:47:08
Добрый вечер! Спасибо за участие. Прокачусь,проверю как стало. На объект очень уж старые фото,решил освежить.
21 January 2022, 14:47:52
21 January 2022, 15:14:03
21 January 2022, 15:16:16
21 January 2022, 15:16:47
21 January 2022, 15:17:05
21 January 2022, 15:17:25
21 January 2022, 15:18:09
Прошу простить ,вышло боком.
30 January 2022, 08:41:25
Добрый день. Про спину она так и не заговорила. Ни словечка. Если можно,сделайте доброе дело.
01 February 2022, 13:37:33
01 March 2022, 17:06:53
Добрый вечер! Спасибо. Работает предупреждение в спину.Хорошего настроения.
14 January 2024, 07:29:42
Спасибо. Красавцы!
29 January 2024, 10:39:34
, changed object type from  Lane Control Camera Lane Control Camera to  Red light detection camera Red light detection camera.
