22 October 2026, 16:04:47
For the past 24 hours: 51 object added, 81 object edited, 18 objects removed.
Автодория (в спину) [47-44км]
04 August 2017, 21:58:34
04 August 2017, 21:59:26
05 August 2017, 07:50:58
а питание к ней подводится или там АКБ?
05 August 2017, 08:48:25
2 кабеля от коробки внизу
05 August 2017, 12:16:49
Автодория, измеряет среднюю скорость на участке
05 August 2017, 14:32:39
я понимаю. пару пока не нашёл. но я ещё и не все скрины с рега + новые точки MCD разобрал. может выстрелит из оставшихся что то.
07 August 2017, 09:35:30
yohan, changed control area.
yohan, changed object type from   to  Twin camera Twin camera.
yohan, changed object description from 'Камера, измеряющая скорость (в спину) ' to 'Автодрия'.
07 August 2017, 09:39:32
yohan, changed object description from 'Автодрия' to 'Автодрия 46-43км'.
07 August 2017, 11:19:26
25 April 2018, 18:50:40
kgs0511, changed object notification distance from 500 to 300.
kgs0511, changed additional information (RU): \"
31 August 2018, 21:03:03
14 September 2018, 18:30:25
29 September 2019, 20:30:14
УльяновскGSM, changed object description from 'Автодрия 46-43км' to 'Автодрия 47-44км'.
29 September 2019, 20:30:43
УльяновскGSM, changed object description from 'Автодрия 47-44км' to 'Автодрия (в спину) [47-44км]'.
30 September 2019, 07:21:58
Благодарю
29 September 2019, 20:30:58
Подтверждено штрафом +1
29 September 2019, 20:31:01
29 September 2019, 20:31:04
29 September 2019, 20:32:10
03 March 2020, 18:26:53
Timon34, changed object description from 'Автодрия (в спину) [47-44км]' to 'Автодория (в спину) [47-44км]'.
03 March 2020, 18:27:12
03 March 2020, 18:27:26
см выше, демонтаж -1
03 March 2020, 18:27:29
03 March 2020, 18:27:31
03 March 2020, 18:28:12
03 March 2020, 18:28:16
03 March 2020, 18:28:19
