20 November 2026, 08:22:38
Лобачевский [885км]
17 July 2017, 22:54:40
17 July 2017, 22:58:05
yohan, changed control area.
29 May 2018, 15:23:38
Timon34, changed object description from 'Автодория [Каспий 886-884,5км] ' to 'Автодория [Р-22 8875-885км] '.
29 May 2018, 15:23:58
Timon34, changed object description from 'Автодория [Р-22 8875-885км] ' to 'Автодория [Р-22 887-885км] '.
02 March 2020, 13:52:51
02 March 2020, 13:53:21
см выше, демонтаж, пока в ноль -1
02 March 2020, 13:53:23
02 March 2020, 13:53:25
07 June 2020, 17:23:16
07 June 2020, 17:23:20
07 June 2020, 17:23:23
09 July 2020, 17:05:26
Timon34, changed object latitude from 43.996775 to 43.990953
Timon34, changed object longitude from 49.337364 to 49.340266
09 July 2020, 17:05:32
Timon34, changed object latitude from 43.990953 to 43.986447
Timon34, changed object longitude from 49.340266 to 49.342615
09 July 2020, 17:06:07
Timon34, changed object latitude from 43.986447 to 43.983648
Timon34, changed object longitude from 49.342615 to 49.344078
Timon34, changed object description from 'Автодория [Р-22 887-885км] ' to 'Астра-Трафик'.
09 July 2020, 17:06:18
Timon34, changed warning direction from 127 to 130.
09 July 2020, 17:06:37
Актуализация, установили Астра-Трафик +1
09 July 2020, 17:06:40
09 July 2020, 17:06:56
мото 0 +1
09 July 2020, 17:07:38
09 July 2020, 17:07:41
14 August 2020, 13:26:40
Волгоградская область, Иловлинский район, ФАД Р-22 Тамбов - Волгоград - Астрахань, 885 км
14 August 2020, 13:26:53
Timon34, changed object description from 'Астра-Трафик' to 'Астра-Трафик [885км]'.
27 October 2020, 18:31:41
27 October 2020, 18:43:19
Есть подтверждение штрафом +1
27 October 2020, 18:43:23
Есть подтверждение штрафом -1
27 October 2020, 18:43:55
27 October 2020, 18:45:10
Прошу плюс добавить к грузовым.. Промахнулся..))
27 October 2020, 18:45:06
Timon34, changed object notification distance from 500 to 600.
27 October 2020, 18:45:53
Подтверждено +1
27 October 2020, 18:46:55
500 метров- не маловато?? И по координатам уточнить бы,- судя по координатам в штрафе, ошибка может составлять метров 70-80..
27 October 2020, 19:02:06
Вы абсолютно правы, стоит на первой опоре, передвинул на более точные координаты
27 October 2020, 19:00:37
Timon34, changed object latitude from 43.983648 to 43.984329
Timon34, changed object longitude from 49.344078 to 49.343706
Timon34, changed warning direction from 130 to 129.
05 May 2021, 20:53:25
01 November 2021, 10:19:38
И эту Астру демонтировали. Не понятно, вернут или нет. Штрафы с нее шли с завидным постоянством
01 November 2021, 16:22:55
13 April 2022, 16:10:04
Timon34, changed warning direction from 129 to 312.
Timon34, changed object description from 'Астра-Трафик [885км]' to 'Лобачевский [885км]'.
13 April 2022, 16:11:01
Timon34, changed object view angle from 20 to 25.
13 April 2022, 16:11:51
Замена на Лобачевского
14 April 2022, 18:38:03
yohan, turned off test mode
