22 October 2026, 08:13:58
Russian Federation > Брянская область
07 January 2022, 09:03:55
07 January 2022, 14:28:12
20 February 2022, 15:25:54
DiK57, changed object notification distance from 700 to 500.
20 February 2022, 15:26:16
DiK57, changed object view angle from 15 to 20.
02 June 2022, 15:43:25
Знак 50 повесили.
02 June 2022, 15:44:20
janbrk, changed speed limit from 90 to 50.
janbrk, changed speed limit from 70 to 50.
07 June 2022, 14:53:27
Timon34, changed object description from 'СКАТ-С' to 'КОРДОН-М 2 [138км 350м]'.
07 June 2022, 14:54:02
СКАТ заменили на Кордон-М 2. В остальном, включая ограничение 50, без изменений
01 November 2022, 06:24:42
28 May 2024, 06:45:15
Штраф. Ограничение скорости 50. Где знак? +1
28 June 2024, 17:12:56
30 June 2024, 10:24:39
Штраф выше +1
19 May 2025, 14:12:57
, changed object latitude from 34.192846 to 34.192340
, changed object longitude from 53.279548 to 53.279665
, changed warning direction from 290 to 291.
19 May 2025, 16:49:56
Теперь комплекс э таким номером находится тут https://mapcam.info/speedcam/point.php?idm=h7SPeRaH2Wl
20 May 2025, 16:27:18
Демонтирован. На удаление -1
20 May 2025, 16:27:20
20 May 2025, 16:27:22
20 May 2025, 16:28:30
20 May 2025, 18:22:23
выше -1
20 May 2025, 18:22:25
выше -1
20 May 2025, 18:54:16
Отсутствует -1
20 May 2025, 18:54:18
Отсутствует -1
20 May 2025, 19:41:35
20 May 2025, 19:43:33
, changed object description from 'КОРДОН-М 2 [138км 350м]' to 'архив'.
