23 October 2026, 05:53:44
04 November 2019, 20:34:21
05 November 2019, 05:47:17
fantompg, changed object latitude from 37.620553 to 37.620500
fantompg, changed object longitude from 55.664046 to 55.664056
fantompg, changed warning direction from 208 to 200.
fantompg, changed object notification distance from 150 to 250.
fantompg, changed object view angle from 15 to 20.
fantompg, changed object description from 'Стрелка М' to 'Стрелка-М'.
05 November 2019, 05:47:34
05 November 2019, 05:54:01
05 November 2019, 06:26:40
Начал стоять с выходных, ориентировочно с субботы (02.11.19)
05 February 2020, 13:03:22
Подтверждено 2020-01-28 13:47:06 (UTC±00:00)
     Вероятность: 91 %  (Частота за прошлый месяц)
19 February 2020, 18:16:23
balabol.1974, changed warning direction from 200 to 202.
balabol.1974, changed object view angle from 20 to 15.
19 February 2020, 18:19:05
Убрал от съезда на Коломенский пр-д, где установлена новая камера, на въезде в тоннель.
06 March 2020, 19:27:25
Подтверждено 2020-02-28 13:13:26 (UTC±00:00)
     Вероятность: 92 %  (Частота за прошлый месяц)
15 February 2021, 11:03:05
15 February 2021, 11:04:11
balabol.1974, changed object description from 'Стрелка-М' to 'Стрелка-СТ-М'.
23 March 2022, 08:17:28
не актуально -1
23 March 2022, 08:17:31
не актуально -1
23 March 2022, 08:17:33
не актуально -1
23 March 2022, 08:21:23
Включили Стрелка-Плюс (тыл)
04 April 2022, 15:01:17
См. выше -1
04 April 2022, 15:01:19
См. выше -1
04 April 2022, 15:01:22
См. выше -1
06 April 2023, 16:27:52
007MCD, changed object notification distance from 250 to 100.
007MCD, changed object view angle from 15 to 10.
02 April 2024, 02:13:34
, changed object description from 'Стрелка-СТ-М' to 'архив'.
