22 October 2026, 09:32:34
Mesta 2200, 297.121 км М1(E30), 100 км/ч
Belarus > Минская область
24 May 2010, 12:35:30
25 May 2010, 20:08:26
30 May 2010, 13:16:28
28 September 2010, 19:23:43
14 November 2010, 16:10:57
26 July 2012, 12:12:35
работает +1
28 May 2013, 17:13:33
Rohierd, changed speed limit from 100 to 80.
13 June 2013, 06:00:46
Камера видеонаблюдения 297 км, Трасса М1
Технические устройства фиксируют факт превышения установленной скорости движения для конкретного участка дороги. Камеры в обоих направлениях
- Фотокамеры ГАИ -, - Трасса M1 -, 297 км
График работы: круглосуточно
По данным ГАИ
http://mogu.by/organizacii/Photokameri-gai-trassa-m1-ul-297-km/kamera-videonablydeniia-297-km-trassa-m1/
она стоит перед перекрёстком ближе к Столбцам
26 July 2013, 05:09:38
alf2, changed object description from 'Камера снимает сзади' to 'Mesta 2200'.
10 August 2013, 09:57:56
mixdm, changed object description from 'Mesta 2200' to 'Mesta 2200, 297км М1'.
26 October 2013, 22:07:44
, changed speed limit from 80 to 100.
26 October 2013, 22:10:48
с обоих сторон перед камерами стоят ограничения 100
29 August 2015, 18:51:42
Опять поменяли на 80
04 April 2016, 13:59:47
YuNew, changed speed limit from 100 to 120.
04 April 2016, 14:04:02
YuNew, changed speed limit from 120 to 100.
04 April 2016, 14:19:36
YuNew, changed object description from 'Mesta 2200, 297км М1' to 'Mesta 2200, 297км М1, 120 км/ч'.
04 April 2016, 14:23:57
YuNew, changed object description from 'Mesta 2200, 297км М1, 120 км/ч' to 'Mesta 2200, 297км М1, контроль скорости 120 км/ч'.
17 June 2016, 00:50:11
YuNew, changed object latitude from 26.905818 to 26.905802
YuNew, changed object longitude from 53.539274 to 53.539348
YuNew, changed warning direction type from Two directions to In a certain direction.
YuNew, changed warning direction from 68 to 69.
24 July 2016, 15:20:29
Hyundi505, changed object type from  Static speed camera Static speed camera to   .
24 July 2016, 17:13:58
Hyundi505, changed object type from   to  Static speed camera Static speed camera.
24 July 2016, 17:22:56
04 August 2016, 10:47:18
Hyundi505, changed object latitude from 26.905802 to 26.905700
Hyundi505, changed object longitude from 53.539348 to 53.539333
09 January 2017, 18:40:49
Heckfy66, changed control area.
09 January 2017, 18:42:36
10 January 2017, 08:31:24
YuNew, changed control area.
YuNew, changed object description from 'Mesta 2200, 297км М1, контроль скорости 120 км/ч' to 'Mesta 2200, 297км, М1(E30), 120 км/ч'.
05 March 2017, 02:23:47
YuNew, changed object description from 'Mesta 2200, 297км, М1(E30), 120 км/ч' to 'Mesta 2200, 297 км, М1(E30), 120/100 км/ч'.
18 November 2017, 15:33:44
05 June 2018, 07:23:09
YuNew, changed object description from 'Mesta 2200, 297 км, М1(E30), 120/100 км/ч' to 'Mesta 2200, 297.121 км М1(E30), 120/100 км/ч'.
YuNew, changed camera model.
YuNew, changed additional information (RU): \"
15 June 2018, 20:26:08
Расслабон, changed control area.
Расслабон, changed speed limit from 120 to 100.
Расслабон, changed object description from 'Mesta 2200, 297.121 км М1(E30), 120/100 км/ч' to 'Mesta 2200, 297.121 км М1(E30), 100 км/ч'.
26 July 2018, 07:52:20
12 January 2021, 12:50:04
Повернули камеру, теперь стреляет в лоб
13 January 2021, 15:23:49
Расслабон, changed object type from   to  Static speed camera Static speed camera.
Расслабон, changed object notification distance from 500 to 600.
30 June 2021, 13:28:03
Неактуально -1
30 June 2021, 13:28:07
Неактуально -1
30 June 2021, 13:28:12
Неактуально -1
30 June 2021, 14:29:59
01 July 2021, 08:29:29
неактуально, камера перенесена вперед -1
01 July 2021, 08:29:35
01 July 2021, 08:29:39
01 July 2021, 09:00:43
См. Выше -1
01 July 2021, 09:00:48
См. Выше -1
01 July 2021, 09:00:52
См. Выше -1
01 July 2021, 11:42:29
01 July 2021, 11:42:34
01 July 2021, 11:42:37
01 July 2021, 16:43:58
01 July 2021, 16:44:02
01 July 2021, 16:44:05
01 July 2021, 22:00:08
См выше -1
01 July 2021, 22:00:12
См выше -1
01 July 2021, 22:00:15
См выше -1
02 July 2021, 06:33:07
02 July 2021, 06:33:25
Elen, changed object notification distance from 600 to 100.
06 July 2021, 23:19:18
Заканчиваю удаление -1
06 July 2021, 23:19:46
Закончил удаление. -1
