22 October 2026, 07:32:01
КОРДОН-М2 (в спину)
Russian Federation > Брянская область
15 February 2020, 10:52:13
15 February 2020, 11:36:41
sutener, changed object type from   to  Static speed camera Static speed camera.
sutener, changed speed limit from 50 to 60.
sutener, changed speed limit from 0 to 60.
sutener, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'скат-с'.
sutener, confirmed object added via Mapcam.info program
15 February 2020, 12:08:17
serezhka, changed warning direction type from Two directions to In a certain direction.
serezhka, changed object description from 'скат-с' to 'СКАТ-С'.
16 February 2020, 10:03:33
Не актуально для мото 0 -1
11 August 2020, 14:08:42
Нет ее
11 August 2020, 14:28:51
Нет ее -1
11 August 2020, 14:28:54
Нет ее -1
11 August 2020, 14:28:56
Нет ее -1
07 November 2020, 18:08:29
см. выше -1
07 November 2020, 18:08:33
см. выше -1
07 November 2020, 18:08:36
см. выше -1
09 June 2021, 12:51:32
Установлен Кордон вместо СКАТ-С. +1
09 June 2021, 12:51:37
09 June 2021, 12:51:55
dansoftware, changed camera model.
09 June 2021, 12:52:15
dansoftware, changed object description from 'СКАТ-С' to 'Кордон'.
09 June 2021, 16:43:27
Выше +1
09 June 2021, 16:43:34
Выше +1
09 June 2021, 16:44:55
Выше +1
09 June 2021, 17:25:32
DiK57, changed object type from  Static speed camera Static speed camera to   .
09 June 2021, 17:25:50
DiK57, changed object notification distance from 500 to 300.
09 June 2021, 17:26:31
Поднимите мото рейтинг
09 June 2021, 17:27:34
09 June 2021, 17:28:46
DiK57, changed object description from 'Кордон' to 'Кордон (в спину)'.
09 June 2021, 18:25:23
мото +1
09 June 2021, 18:25:47
09 June 2021, 18:57:16
Спасибо с телефона тяжело это сделать
09 June 2021, 18:56:27
DiK57, changed control area.
DiK57, changed object description from 'Кордон (в спину)' to 'КОРДОН-М2 (в спину)'.
DiK57, changed camera model.
22 June 2021, 08:20:27
DiK57, changed object latitude from 35.049887 to 35.049553
DiK57, changed object longitude from 53.116263 to 53.116309
31 August 2021, 19:30:08
yuryleb, changed warning direction from 99 to 100.
31 August 2021, 19:35:54
31 August 2021, 19:37:12
31 August 2021, 19:37:18
Штраф -1
31 August 2021, 19:37:31
31 August 2021, 19:37:40
16 October 2021, 14:56:22
16 October 2021, 14:56:48
iDimiON, changed speed limit from 60 to 40.
09 November 2021, 09:01:31
Опять убрали https://yandex.ru/maps/-/CCUuY2W02D
09 November 2021, 09:12:18
Демонтирован на удаление -1
09 November 2021, 09:12:21
09 November 2021, 09:12:25
15 November 2021, 19:12:05
15 November 2021, 19:12:12
15 November 2021, 19:12:18
15 November 2021, 19:17:13
Демонтирована -1
15 November 2021, 19:17:24
Демонтирована -1
