22 October 2026, 13:23:20
Лобачевский (тыл) [885км]
17 July 2017, 22:55:32
17 July 2017, 22:57:28
yohan, changed control area.
29 May 2018, 06:09:16
29 May 2018, 06:10:29
Актуально. +1
29 May 2018, 15:22:57
Timon34, changed object description from 'Автодория [Каспий 884,5-886км] ' to 'Автодория [Р-22 885-887км] '.
11 April 2019, 05:06:06
02 March 2020, 13:52:42
02 March 2020, 13:53:05
см выше, демонтаж -1
02 March 2020, 13:53:08
02 March 2020, 15:12:03
Обнулил по просьбе -1
02 March 2020, 15:12:07
02 March 2020, 15:12:16
Обнулил по просьбе, смотреть выше -1
07 June 2020, 17:23:42
07 June 2020, 17:23:46
07 June 2020, 17:23:49
09 July 2020, 17:01:47
Timon34, changed object latitude from 43.980456 to 43.983633
Timon34, changed object longitude from 49.345798 to 49.344049
Timon34, changed object type from  Twin camera Twin camera to   .
Timon34, changed warning direction from 317 to 311.
Timon34, changed object description from 'Автодория [Р-22 885-887км] ' to 'Астра-Трафик (тыл)'.
09 July 2020, 17:02:38
Актуализация, установили Астра-Трафик +1
09 July 2020, 17:02:44
09 July 2020, 17:02:47
09 July 2020, 17:05:45
09 July 2020, 17:05:48
09 July 2020, 17:05:51
14 August 2020, 13:27:22
Timon34, changed object description from 'Астра-Трафик (тыл)' to 'Астра-Трафик (тыл) [885км]'.
04 September 2020, 06:46:01
04 September 2020, 15:45:23
Ваш штраф из этой точки https://mapcam.info/speedcam/point.php?idm=d7ZhwbNLdJ5 Просьба выложить его туда
27 October 2020, 19:04:14
Timon34, changed object latitude from 43.983633 to 43.984308
Timon34, changed object longitude from 49.344049 to 49.343687
Timon34, changed object notification distance from 450 to 500.
01 November 2021, 10:19:50
И эту Астру демонтировали. Не понятно, вернут или нет. Штрафы с нее шли с завидным постоянством
01 November 2021, 16:22:42
13 April 2022, 16:10:52
Timon34, changed warning direction from 311 to 129.
Timon34, changed object view angle from 25 to 20.
Timon34, changed object description from 'Астра-Трафик (тыл) [885км]' to 'Лобачевский (тыл) [885км]'.
13 April 2022, 16:11:58
Замена на Лобачевского
14 April 2022, 18:37:37
yohan, turned off test mode
