17 November 2026, 23:34:17
For the past 24 hours: 93 objects added, 89 objects edited, 13 objects removed.
Стрелка-Плюс
20 November 2018, 17:57:25
20 November 2018, 17:56:07
john.77, changed object latitude from 37.547289 to 37.547445
john.77, changed object longitude from 55.867269 to 55.866926
john.77, changed warning direction from 166 to 167.
20 November 2018, 17:56:44
Сегодня установили напротив остановки общественного транспорта. Добавлю фото завтра
20 November 2018, 18:25:47
Yald, changed camera model.
20 November 2018, 18:27:03
Yald, changed object latitude from 37.547445 to 37.547356
Yald, changed object longitude from 55.866926 to 55.866945
Yald, changed warning direction from 167 to 160.
Yald, changed object notification distance from 300 to 400.
20 November 2018, 18:27:59
МОТО-рейтинг ноль. -1
22 November 2018, 06:52:17
22 November 2018, 06:53:21
22 November 2018, 06:53:34
22 November 2018, 09:11:26
05 December 2018, 15:26:37
, changed object description from 'Стрелка-М-Р' to 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)'.
05 December 2018, 15:27:11
05 December 2018, 15:27:28
Рейтинг ноль -1
05 December 2018, 15:27:32
Рейтинг ноль -1
23 June 2019, 18:12:27
, changed object latitude from 37.547356 to 37.547433
, changed object longitude from 55.866945 to 55.866910
, changed object type from  Static speed camera Static speed camera to  Stop control camera Stop control camera.
, changed warning direction from 160 to 166.
, changed object description from 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)' to 'Стрелка-М-Р + Стрит Фалькон'.
23 June 2019, 18:12:48
23 June 2019, 18:12:53
23 June 2019, 18:12:57
23 June 2019, 18:27:04
wolf-777, changed object description from 'Стрелка-М-Р + Стрит Фалькон' to 'Стрит Фалькон + МУЛЯЖ! Стрелка-М-Р'.
24 June 2019, 06:09:20
05 March 2020, 23:20:32
05 March 2020, 23:32:59
05 March 2020, 23:28:58
setpiton, changed object type from  Stop control camera Stop control camera to  Lane Control Camera Lane Control Camera.
setpiton, changed object description from 'Стрит Фалькон + МУЛЯЖ! Стрелка-М-Р' to 'Стрелка-М-П + Стрит Фалькон'.
05 March 2020, 23:31:05
Подтверждено штрафом +1
05 March 2020, 23:31:11
05 March 2020, 23:34:27
11 March 2020, 13:43:07
11 March 2020, 14:21:18
А можно сделать так, чтобы понимать, что здесь стрит фалькон? Когда едешь отображается только камера на полосу, на остановку никак не фигурировало. Чуть штраф не поймал из-за этого.
11 March 2020, 14:24:51
Оповещение о контроле остановки звучит через TTS.
11 March 2020, 14:34:20
Что такое TTS? Смею предположить - озвучка? Я езжу в режиме радар с открытой картой без звука. Как быть таким как я? Может можно добавить отдельную точку?
11 March 2020, 15:06:17
Точка на точку наложится.
11 March 2020, 21:34:49
fantompg, что можно сделать? Включать звук и слушать про камеру на остановку очень не хочется, их скоро тысяча будет. Что случится криминального если точка на точку наложится? Это я считаю очень большая недоработка..
29 May 2021, 23:21:22
25 September 2021, 20:30:55
25 September 2021, 20:31:47
25 September 2021, 20:37:30
setpiton, changed object description from 'Стрелка-М-П + Стрит Фалькон' to 'Стрелка-М-П'.
26 December 2021, 15:36:45
26 December 2021, 18:30:33
balabol.1974, changed object description from 'Стрелка-М-П' to 'Стрелка-М-В'.
12 June 2022, 09:42:50
24 June 2022, 20:48:31
24 June 2022, 20:50:22
Коллеги добрый вечер,с какой камеры как думаете?Такой точки не отмечено.
24 June 2022, 20:53:08
Я так понимаю ,что нарушение на дублёре у метро "Селигерская" А вот с какой камеры вопрос.
24 June 2022, 21:06:53
С камеры за парковку, она не отмечена, видимо недавно появилась.
24 June 2022, 21:08:20
ННа Яндексе тоже нет еë
24 June 2022, 21:14:59
2 ГИС отмечена камера на дублëре
01 March 2026, 02:35:26
01 March 2026, 02:35:50
до штрафа -1
01 March 2026, 02:35:56
до штрафа -1
01 March 2026, 02:36:11
Замена.
01 March 2026, 02:37:23
