10 November 2026, 17:49:44
For the past 24 hours: 50 objects added, 85 objects edited, 25 objects removed.
11 December 2018, 07:37:29
11 December 2018, 07:34:39
11 December 2018, 07:52:09
Спасибо плюс.
11 December 2018, 07:49:43
, changed warning direction from 270 to 277.
, changed object description from 'возможно муляж' to 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)'.
11 December 2018, 07:50:11
Рейтинг ноль -1
11 December 2018, 07:50:14
Рейтинг ноль -1
11 December 2018, 07:50:16
Рейтинг ноль -1
10 November 2020, 13:53:40
balabol.1974, changed object type from  Static speed camera Static speed camera to  Lane Control Camera Lane Control Camera.
balabol.1974, changed object description from 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)' to 'Стрелка-М-П'.
10 November 2020, 13:54:07
только грузовым +1
11 November 2020, 16:26:06
11 November 2020, 16:43:26
в центр это здесь я так понимаю: https://mapcam.info/speedcam/point.php?idm=GhxgXcFIeFj
11 November 2020, 16:49:05
Похоже что это  та самая камера которая на первой фото, от строительного рынка в сторону Строгино
11 November 2020, 17:12:15
Здесь камера очень далеко стоит от стоп-линии, да и угол фотографирования совсем другой.
11 November 2020, 16:40:52
актуально +1
11 November 2020, 16:40:56
актуально +1
11 November 2020, 16:42:09
ошибочно -1
11 November 2020, 16:42:12
ошибочно -1
11 November 2020, 16:55:49
Все же отсюда, прошу поднять рейтинг
11 November 2020, 16:57:11
DarkMatter, changed control area.
DarkMatter, changed object type from  Lane Control Camera Lane Control Camera to   .
DarkMatter, changed object description from 'Стрелка-М-П' to 'Стрелка-М-П (тыл)'.
11 November 2020, 17:13:02
11 November 2020, 17:30:28
См выше. Актуально +1
11 November 2020, 17:30:31
11 November 2020, 17:39:56
DarkMatter, changed object notification distance from 200 to 250.
11 November 2020, 18:42:12
DarkMatter, changed object latitude from 37.385726 to 37.386021
DarkMatter, changed object longitude from 55.809043 to 55.809000
11 November 2020, 18:54:05
balabol.1974, changed object latitude from 37.386021 to 37.386144
balabol.1974, changed object longitude from 55.809001 to 55.809017
11 November 2020, 18:59:04
11 November 2020, 19:00:30
разметку, наверное, может контролировать. нет?
11 November 2020, 19:02:57
11 November 2020, 20:03:21
Подтверждено +1
11 November 2020, 20:03:25
Подтверждено +1
11 November 2020, 20:03:28
Подтверждено +1
12 November 2020, 06:22:24
15 November 2020, 19:45:04
Сколько секунд надо стоять остановившись перед стоп-линией?
06 December 2020, 20:30:23
надо остановится, выйти,  присесть сказать ку и тогда точно не оштрафуют)
16 November 2020, 10:11:59
[/url]
24 November 2020, 19:47:33
25 November 2020, 08:11:11
25 November 2020, 19:08:09
Просьба не завышать рейтинг предупреждения с каждым полученным сканом. Рейтинг предупреждения плюс 2 и так означает что камера уже включена.
25 November 2020, 19:07:05
завышен -1
26 November 2020, 18:46:10
04 December 2020, 15:19:57
06 December 2020, 20:22:47
25 December 2020, 02:29:03
29 December 2020, 20:16:49
Актуально. +1
03 January 2021, 13:30:27
03 January 2021, 13:31:46
Актуально. Стоп линия.
22 January 2021, 17:03:26
22 January 2021, 17:03:49
Актуально.
27 January 2021, 15:36:31
27 January 2021, 15:39:33
 Текущий вид.Тоже попал. В постановлении указано "Стрелка-М"-В
29 January 2021, 13:08:00
Ashkrmane, changed object description from 'Стрелка-М-П (тыл)' to 'Стрелка-М-В (тыл)'.
02 February 2021, 14:16:42
02 February 2021, 14:17:17
Поверка до 24.06.2022
23 March 2021, 18:33:36
04 April 2021, 07:38:43
Измените на предупреждение о фиксации пересечения стоп линии. По комментариям похоже камера с января 2021 года фиксирует Стоп линию
08 April 2021, 20:27:32
22 May 2021, 21:48:41
balabol.1974, changed speed limit from 60 to 10.
21 June 2021, 21:36:15
21 June 2021, 21:40:22
12.16.1 - Несоблюдение требований знаков или разметки (знак STOP)
27 June 2021, 04:31:22
30 June 2021, 04:10:49
16 July 2021, 06:00:11
28 September 2021, 22:20:22
28 September 2021, 22:20:46
12 January 2022, 20:53:54
12 January 2022, 20:54:37
24 December 2022, 23:24:47
24 March 2023, 10:06:46
29 March 2023, 05:49:05
29 March 2023, 05:52:37
29 March 2023, 05:52:56
30 May 2023, 19:03:16
14 August 2023, 11:30:54
Знак стоп и стоп линия убраны. Весит знак уступи дорогу.
14 August 2023, 11:30:56
14 August 2023, 11:47:42
18 September 2023, 13:47:52
ДЕМОНТАЖ -1
18 September 2023, 13:47:56
ДЕМОНТАЖ -1
18 September 2023, 13:47:59
ДЕМОНТАЖ -1
18 September 2023, 15:08:17
18 September 2023, 15:08:21
18 September 2023, 15:08:25
18 September 2023, 15:11:27
007MCD, changed control area.
007MCD, changed control direction from In the back to Counter direction.
007MCD, changed object notification distance from 250 to 100.
007MCD, changed object view angle from 15 to 10.
007MCD, changed object description from 'Стрелка-М-В (тыл)' to 'демонтаж'.
18 September 2023, 17:04:47
выше -1
18 September 2023, 17:04:52
выше -1
18 September 2023, 17:04:56
выше -1
18 September 2023, 18:40:24
См выше.Демонтаж.Удалил -1
02 April 2024, 05:04:24
