22 October 2026, 08:13:49
КРИС-П
24 June 2015, 08:17:06
24 June 2015, 08:19:45
24 June 2015, 09:39:46
Фото это плюс завсегда
24 June 2015, 09:43:42
Зеленый сектор должен быть направлен в лицо водителя, которого необходимо предупредить, не зависимо от того как работает тренога: в лоб или в зад. У Вас правильно стоит точка?
24 June 2015, 11:22:50
deksven_dair, changed object description from 'Мобильная камера (засада)' to 'КРИС-П'.
25 June 2015, 08:14:20
есть актуальное подтверждение, рейтинг точки от 2. +1
18 September 2015, 12:09:50
20 February 2016, 09:33:55
09 April 2016, 14:16:31
Долго же ты фотку хранил ))))
18 April 2016, 10:38:13
КРИС-П, 40 км/ч
КРИС-П, 40 км/ч
26 September 2016, 13:40:55
deksven_dair, changed warning start time from 0 to 8.
07 December 2016, 05:51:15
02 November 2017, 00:44:23
КРИС-П, 40 км/ч
КРИС-П, 40 км/ч
02 November 2017, 00:44:40
25 May 2018, 09:44:00
25 May 2018, 09:44:24
09 July 2018, 10:20:20
15 January 2019, 12:34:11
Primorets, changed warning direction type from In a certain direction to Two directions.
Primorets, changed warning direction from 271 to 272.
Primorets, changed object notification distance from 435 to 400.
15 January 2019, 12:34:41
08 April 2019, 13:20:11
Narart, changed additional information (RU): \"
18 November 2019, 20:40:59
05 September 2021, 15:21:07
Неактуально -1
05 September 2021, 15:21:13
Неактуально -1
05 September 2021, 15:21:17
Неактуально -1
05 September 2021, 16:17:40
05 September 2021, 16:17:43
05 September 2021, 16:17:46
05 September 2021, 17:00:45
Неактуально -1
05 September 2021, 17:00:55
Неактуально -1
05 September 2021, 17:01:00
Неактуально -1
05 September 2021, 19:36:37
См.выше. Удалил. -1
05 September 2021, 19:36:41
См.выше. Удалил. -1
05 September 2021, 19:36:46
См.выше. Удалил. -1
