03 November 2026, 20:05:39
For the past 24 hours: 48 objects added, 63 objects edited, 5 objects removed.
КОРДОН-ТЕМП (в спину) [681км 395м]
Ukraine > Крим
21 November 2018, 19:08:14
22 November 2018, 04:41:49
Atlay, changed control area.
Atlay, changed object notification distance from 600 to 800.
Atlay, changed object view angle from 40 to 45.
22 November 2018, 10:11:09
DiK57, changed object notification distance from 800 to 400.
22 November 2018, 13:00:46
Atlay, changed object notification distance from 400 to 700.
26 November 2018, 10:35:23
DiK57, changed object notification distance from 700 to 400.
26 November 2018, 10:36:07
Для камеры в спину 700 это слишком много
02 January 2019, 18:56:43
Она не только в спину бьёт.
02 January 2019, 18:36:12
Timon34, changed object description from 'контроль скорости в спину' to 'Призма-Stos в спину'.
02 January 2019, 18:56:04
Atlay, changed camera model.
02 January 2019, 19:04:24
Timon34, changed object notification distance from 700 to 300.
02 January 2019, 19:14:29
Ну зачем 300 поставили? Она вперед тоже бьёт. Или из вредности?
03 January 2019, 08:10:23
03 January 2019, 08:33:56
09 January 2019, 08:42:24
09 January 2019, 08:43:07
При проезде этого участка камеры не обнаружено.
24 January 2019, 07:01:06
До подтверждения опасности или удаления -1
24 January 2019, 07:01:09
24 January 2019, 07:01:11
02 February 2019, 14:26:11
Камеру сняли.
16 February 2019, 12:39:27
Камеру вернули. +1
16 February 2019, 12:40:22
вернули. +1
16 February 2019, 12:40:29
вернули. +1
23 February 2019, 13:09:27
23 February 2019, 13:12:09
Yra. Mapcam 777, changed object latitude from 34.336374 to 34.336363
Yra. Mapcam 777, changed object longitude from 44.818645 to 44.818381
Yra. Mapcam 777, changed control area.
24 February 2019, 08:10:36
Atlay, changed object latitude from 34.336363 to 34.336404
Atlay, changed object longitude from 44.818381 to 44.818535
Atlay, changed warning direction from 324 to 329.
Atlay, changed object notification distance from 300 to 294.
18 April 2019, 09:16:56
Atlay, changed additional information (RU): \"
18 April 2019, 09:17:48
21 April 2019, 05:56:21
alex_605, changed object notification distance from 294 to 400.
alex_605, changed object description from 'Призма-Stos в спину' to 'Призма-Stos (в спину)'.
alex_605, changed camera model.
21 April 2019, 07:54:56
Atlay, changed object notification distance from 400 to 300.
26 April 2019, 17:54:44
Timon34, changed object description from 'Призма-Stos (в спину)' to 'Призма-Stos (в спину) [681км 395м]'.
01 June 2019, 03:35:15
alex_605, changed object description from 'Призма-Stos (в спину) [681км 395м]' to 'Автодория 3.0 (в спину) [681км 395м]'.
20 September 2019, 13:58:46
Sergey1995, changed object description from 'Автодория 3.0 (в спину) [681км 395м]' to 'КОРДОН-ТЕМП (в спину) [681км 395м]'.
Sergey1995, changed camera model.
06 August 2020, 10:54:26
Sergey1995, changed control area.
Sergey1995, changed object type from   to  Static speed camera Static speed camera.
06 August 2020, 10:54:43
Sergey1995, changed object type from  Static speed camera Static speed camera to   .
Sergey1995, changed object notification distance from 300 to 400.
30 August 2021, 12:52:58
30 August 2021, 12:53:43
Перед камерой ограничение 60, поясните, какое ограничение скорости фиксирует камера?
30 August 2021, 14:35:23
Реально 80
30 August 2021, 14:36:54
А почему у всех камер настройка на 90 км/ч? Ограничение ввели недавно и никто не поменял?
30 August 2021, 15:38:37
Не знаю, я там месяц назад был последний раз. Было всё по старому.  Активных участников нужно спросить, а то где не надо, по 100 раз всё меняют.
01 September 2021, 19:23:45
Я проехал под этой камерой "на 60" 100-105 км/ч аж три раза в разные дни, здесь точно 90. И знак 60 тут недействителен, нужно ступенчатое понижение скорости с шагом не более 20 км (90-70-60 здесь должно быть)
30 August 2021, 12:54:15
sademid51, changed control area.
