21 November 2026, 19:32:30
For the past 24 hours: 46 objects added, 58 objects edited, 4 objects removed.
СКАТ (в спину) [1055км 54м]
14 June 2020, 18:59:32
14 June 2020, 19:03:01
По фоткам на [url=https://yandex.ru/maps/11031/aksay/?l=mrc
14 June 2020, 19:03:50
Пока не понятно какое нарпавление контролируется
14 June 2020, 19:23:09
УльяновскGSM, changed object notification distance from 300 to 400.
14 June 2020, 20:45:09
УльяновскGSM, changed object description from 'СКАТ (в спину)' to 'СКАТ (в спину) [1055км 240м]'.
05 June 2021, 05:11:42
Радар начал давать сигнал +1
16 December 2021, 10:17:36
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAABDcAAAIdCAYAAAApqpa9AAAgAElEQVR4nOy995dU1br1//4Z5oiCSE4d6Zxzzk1nOuec6UQH6CaoCJKDQAtITg0ICEhGFCQHQSSDIiDg0TO/P9zvfM6qxa6uPnrPfd87hj3GGkrVjrWr9l7rs acz//B339///399/ff339///399/ff339///399/ff339///399/ff/ K//8P/SUtLQ1paGlJTU5Gamoq0tDSkp6cjMzMTWVlZSEpKQlJSEpKTk5GcnIyUlBRZlstz/ZSUFCQnJ8s6SUlJJsvyfXUZfbtpaWkYP3480tPTkZ6ebrIto5aWlibbTUxMREJCAhISEpCYmIjExESTZfX9mDt2LmfU1M8oIyNDWmZmpnxmWVlZyM7OlpaVlYWMjAykp6dj/Pjx0vhvbovbUJfNzMxEdnY2cnNzkZeXh7y8POTk5CAzMxPp6enIyspCTk4O8vLykJ fj/z8fFmGx8Lt8vhycnKQm5v73PKZmZkYP348UlNT5bOIjo5GeHg4goKC4O3tDTc3Nzg5OcHBwQEODg7w8vKCl5cXvL294eXlBXd3d7i4uMDBwQF2dnawtbWFnZ0dHBwc4OrqCh8fH4SEhCA6Ohrjxo1DYmIiYmNjER4ejpCQEISFhSEqKgrx8fFyHTMyMpCbm4uCggLU1NRg2rRpWLJkCVasWIFVq1ZhzZo12LBhA7Zs2YKenh709PRg69at2LJlC3bs2IFdu3Zh3bp1WLBgAaZOnYri4mKkpKTIZ9bQ0ICdO3diw4YN Oqrr7Br1y7s3r0b /btw8GDB3Hw4EEcOnQIhw8fxpEjR3DkyBEcPXoUR48exddff91r /bbb/HNN9/g66 /xpEjR3D48GEcOnRImrp9/nv//v3Yt28f9u7di2PHjsm 1PW53p49e7B3717s3bsXX331Ffbv348DBw7I 3yNr6vv8X19GfV9/vvQoUMm583Pg
16 December 2021, 10:18:56
16 December 2021, 10:20:01
Ехал в сторону Москвы. Стреляет в зад как видно на фото.
16 December 2021, 11:01:29
плюс в карму
16 December 2021, 11:06:05
УльяновскGSM, changed object description from 'СКАТ (в спину) [1055км 240м]' to 'СКАТ (в спину) [1055км 54м]'.
16 December 2021, 11:14:47
05 December 2022, 06:18:20
примерно все лето ~2022 был демонтирован, висел один кронштейн. ~05.11.22 был установлен и включен. 14.11.22 снова снят и по сей день отсутствует
10 December 2022, 23:28:27
[img=16x16]https://mapcam.info/images/im_off.gif[/img] 09.12 отсутствовал 10.12 появился в боевом режиме
15 April 2023, 01:50:27
11.04 и 14.04 все еще отсутствие
