25 September 2026, 06:23:58
For the past 24 hours: 145 objects added, 114 objects edited, 7 objects removed.
АРЕНА-СМ
02 February 2026, 12:24:27
02 February 2026, 12:26:58
, changed object type from   to  Static speed camera Static speed camera.
, changed speed limit from 0 to 60.
, changed warning direction from 121 to 283.
, changed object notification distance from 500 to 450.
, changed object description from 'Объект добавлен 2026-02-02 03:08:52 с помощью MapcamDroid' to 'Статическая камера, измеряющая скорость'.
02 February 2026, 12:27:40
, changed object latitude from 39.023311 to 39.023214
, changed object longitude from 45.033656 to 45.033546
02 February 2026, 12:28:58
02 February 2026, 12:34:10
02 February 2026, 12:35:07
Запрятали ловко. Хороший будет улов!
03 February 2026, 06:13:47
04 February 2026, 07:42:34
, changed object description from 'Статическая камера, измеряющая скорость' to 'АРЕНА-СМ'.
17 September 2026, 11:29:23
, changed warning direction from 283 to 286.
, changed object notification distance from 450 to 200.
, changed object view angle from 20 to 25.
17 September 2026, 11:31:18
Подрезал дистанцию до
Пульсара
Today at 05:32:10
, changed warning direction from 286 to 283.
, changed object notification distance from 200 to 500.
Today at 05:58:42
Если ремень и т.д. наверно нужно в комплекс...
Today at 06:05:19
Today at 06:05:21
Today at 06:06:08
Фото здесь
