29 October 2026, 11:25:07
For the past 24 hours: 87 objects added, 99 objects edited, 11 objects removed.
Скат (тыл)
23 February 2023, 10:28:07
23 February 2023, 10:33:35
Сашок Рязань, changed warning start time from 0 to 6.
Сашок Рязань, switched object to test mode
23 February 2023, 11:30:25
Выведите из теста, подтверждение есть
23 February 2023, 11:10:11
Пришёл штраф -1
23 February 2023, 11:10:20
Пришёл штраф +1
23 February 2023, 11:11:00
23 February 2023, 11:11:18
23 February 2023, 11:13:22
hempler, changed object latitude from 39.745251 to 39.745238
hempler, changed object longitude from 54.628611 to 54.628590
hempler, changed warning direction type from In a certain direction to Two directions.
hempler, changed control direction from In the back to Both directions.
hempler, changed warning start time from 6 to 0.
23 February 2023, 11:27:16
serezhka, changed warning direction from 138 to 135.
serezhka, changed object notification distance from 130 to 350.
serezhka, changed object description from 'Камера 40' to 'КОРДОН-М 2'.
23 February 2023, 11:27:31
Подтверждено +1
23 February 2023, 11:27:33
Подтверждено +1
23 February 2023, 11:27:36
Подтверждено +1
23 February 2023, 11:29:32
Спасибо за проделанную работу!
23 February 2023, 11:29:19
serezhka, changed object latitude from 39.745238 to 39.745163
serezhka, changed object longitude from 54.628590 to 54.628549
serezhka, changed warning direction from 135 to 136.
23 February 2023, 11:40:00
Сашок Рязань, changed warning end time from 24 to 0.
Сашок Рязань, turned off test mode
23 February 2023, 14:17:03
Timon34, changed warning end time from 0 to 24.
23 February 2023, 14:18:01
Просьба аккуратнее с этими настройками. Если выставить с 0 до 0, то оповещения от точки не будет
26 February 2024, 07:23:39
26 February 2024, 11:44:26
, changed object latitude from 39.745163 to 39.745194
, changed object longitude from 54.628549 to 54.628587
, changed control direction from Both directions to In the back.
, changed object description from 'КОРДОН-М 2' to 'Скат (тыл)'.
26 February 2024, 11:49:16
26 February 2024, 12:16:07
актуально +1
17 January 2025, 08:57:44
