23 October 2026, 05:53:10
СКАТ-П [97км 800м]
05 August 2018, 18:03:22
06 March 2020, 19:27:25
Подтверждено 2020-03-05 12:48:53 (UTC±00:00)
     Вероятность: 87 %  (Частота за прошлый месяц)
18 March 2020, 13:54:20
uDAV163, changed object latitude from 38.668999 to 38.668868
uDAV163, changed object longitude from 55.181545 to 55.181565
uDAV163, changed warning direction from 11 to 8.
29 October 2020, 17:42:30
16 July 2022, 17:17:58
balabol.1974, changed warning direction from 8 to 2.
balabol.1974, changed object view angle from 35 to 55.
16 July 2022, 17:18:29
завышен -1
08 August 2022, 16:54:24
Около года никого нет.
08 August 2022, 16:54:54
До подтверждения -1
08 August 2022, 16:54:57
До подтверждения -1
08 August 2022, 16:55:12
До подтверждения -1
08 August 2022, 16:58:32
Прошу помочь обнулить.  См. выше
08 August 2022, 17:00:42
см. выше -1
08 August 2022, 17:00:45
см. выше -1
08 August 2022, 17:00:46
см. выше -1
11 April 2024, 02:21:45
Стоят +1
11 April 2024, 02:21:51
Стоят +1
11 April 2024, 02:21:59
Стоят +1
11 April 2024, 09:33:02
, changed object latitude from 38.668868 to 38.668463
, changed object longitude from 55.181565 to 55.180928
, changed warning direction from 2 to 5.
01 November 2024, 09:57:22
стоят
05 November 2024, 21:18:10
, changed object latitude from 38.668463 to 38.668520
, changed object longitude from 55.180928 to 55.180780
, changed object description from 'ОСКОН [97км 780м]' to 'ОСКОН [97км 800м]'.
05 November 2024, 21:19:21
, changed object description from 'ОСКОН [97км 800м]' to 'СКАТ [97км 800м]'.
05 November 2024, 21:20:33
05 November 2024, 21:21:44
Стояла зелёная легковушка с колпаком на крыше, поздно увидел, а приложение предательски молчало((
05 November 2024, 21:22:17
05 November 2024, 21:22:41
Стоят +1
06 November 2024, 03:47:05
, changed object description from 'СКАТ [97км 800м]' to 'СКАТ-П [97км 800м]'.
06 November 2024, 07:28:28
11 March 2025, 06:01:39
Следует минусануть этот объект: никогда комплексы не устанавливают по направлению в Москву.
02 April 2025, 09:39:41
как раз постоянно стоит СКАТ-П и контролирует тех, кто едет из Москвы, а вот в Москву давно не стоят. Так что эта точка актуальна
13 April 2025, 10:57:25
07 May 2025, 14:34:04
13 June 2025, 12:52:02
05 July 2025, 20:00:10
05 July 2025, 20:02:04
10 August 2025, 09:44:31
24 October 2025, 10:57:10
30 April 2026, 07:34:20
