17 November 2026, 22:05:57
19 May 2020, 14:00:17
19 May 2020, 14:00:58
19 May 2020, 14:16:31
19 May 2020, 14:18:48
Yald, changed warning direction from 257 to 259.
Yald, changed object notification distance from 200 to 500.
Yald, changed object description from 'Статическая камера, измеряющая скорость' to 'СКАТ-С'.
Yald, changed camera model.
19 May 2020, 14:19:17
19 May 2020, 19:13:22
balabol.1974, changed object latitude from 38.006837 to 38.007962
balabol.1974, changed object longitude from 55.801281 to 55.801411
19 May 2020, 19:14:25
Переместил на 70 метров
22 June 2020, 16:55:14
22 June 2020, 16:55:24
22 June 2020, 16:55:36
Подтверждено +1
22 June 2020, 16:55:39
Подтверждено +1
22 June 2020, 16:56:07
fantompg, changed object description from 'СКАТ-С' to 'СКАТ-С [25км 950м]'.
30 June 2020, 21:19:52
DarkMatter, changed speed limit from 60 to 80.
30 June 2020, 21:29:54
DarkMatter, changed speed limit from 80 to 60.
05 July 2020, 06:19:20
Поймало +1
05 July 2020, 10:01:39
30 October 2020, 13:03:00
maykl3011, changed object latitude from 38.007962 to 38.007973
maykl3011, changed object longitude from 55.801411 to 55.801455
30 October 2020, 13:04:07
Поставил на середину дороги.
30 October 2020, 13:17:41
maykl3011, changed object description from 'СКАТ-С [25км 950м]' to 'СКАТ-С [26км 040м]'.
22 January 2021, 11:28:59
09 April 2021, 11:38:51
09 April 2021, 11:39:43
Работает
26 June 2022, 07:12:11
ДЕМОНТАЖ -1
26 June 2022, 07:12:14
ДЕМОНТАЖ -1
26 June 2022, 07:12:17
ДЕМОНТАЖ -1
26 June 2022, 07:39:10
26 June 2022, 07:39:15
26 June 2022, 10:11:24
26 June 2022, 10:11:28
14 July 2022, 13:31:38
Сняли обе камеры. -1
14 July 2022, 13:31:43
23 August 2022, 15:46:29
42OI339O, changed object description from 'СКАТ-С [26км 040м]' to 'демонтаж'.
02 February 2023, 12:22:29
kroxan, changed object notification distance from 500 to 100.
kroxan, changed object view angle from 15 to 10.
16 March 2024, 20:00:47
07 January 2026, 20:17:09
, changed object latitude from 38.007973 to 38.007895
, changed object longitude from 55.801455 to 55.801415
, changed object type from  Other danger Other danger to  Traffic control complex Traffic control complex.
07 January 2026, 20:18:54
07 January 2026, 20:20:32
Камеру вернули
07 January 2026, 20:46:42
вернули +1
07 January 2026, 20:46:45
вернули +1
07 January 2026, 20:46:48
вернули +1
07 January 2026, 20:47:58
, changed object notification distance from 100 to 500.
, changed object description from 'архив' to 'СКАТ-С'.
08 January 2026, 07:16:12
Вернули +1
08 January 2026, 07:16:19
Вернули +1
08 January 2026, 07:17:33
Вернули +1
08 January 2026, 11:19:31
, changed object description from 'СКАТ-С' to 'Азимут'.
08 January 2026, 11:19:45
новая +1
17 January 2026, 08:42:27
Камера какая то непонятная. Не похожа на те что фиксируют скорость
17 January 2026, 08:48:39
17 January 2026, 08:48:56
На азимут не похожа
17 January 2026, 08:49:55
Я её несколько раз глазами видел
17 January 2026, 08:52:08
Похожа на эту
18 January 2026, 07:11:09
, changed object latitude from 38.007895 to 38.007777
, changed object longitude from 55.801415 to 55.801422
18 January 2026, 07:11:28
, changed object description from 'Азимут' to '???'.
18 January 2026, 07:12:08
до подтверждения -1
18 January 2026, 07:12:24
до подтверждения -1
19 January 2026, 11:44:35
https://yandex.ru/maps/-/CLhPmFoB блок управления сзади есть
20 January 2026, 07:55:26
20 January 2026, 09:33:44
Да, на стандартный Азимут непохожа. Либо что-то новое, либо обычное видеонаблюдение.
20 January 2026, 08:05:50
20 January 2026, 08:06:35
Общий вид, других камер не видно
20 January 2026, 08:06:36
20 January 2026, 08:06:43
20 January 2026, 08:06:45
20 January 2026, 16:05:31
Заклинило...
20 January 2026, 16:05:44
Заклинило...
20 January 2026, 09:34:01
, changed object notification distance from 500 to 200.
20 May 2026, 05:12:59
20 May 2026, 05:39:00
Такаеже камера висит далее на обочине в сторону Москвы
30 August 2026, 13:37:28
30 August 2026, 13:37:29
