04 October 2026, 05:49:52
For the past 24 hours: 38 objects added, 28 objects edited, 5 objects removed.
Метео
14 January 2014, 17:55:59
11 April 2016, 16:44:07
2maxic, changed object description from 'Мобильная камера (засада)' to 'Мобильная засада (контроль скорости)'.
22 February 2017, 21:18:05
Какова актуальность точки?
23 March 2017, 10:07:11
logan219, changed object latitude from 45.819519 to 45.817974
logan219, changed object longitude from 51.660001 to 51.664447
logan219, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to  Static speed camera Static speed camera.
logan219, changed warning direction type from Two directions to In a certain direction.
logan219, changed warning direction from 168 to 348.
logan219, changed object description from 'Мобильная засада (контроль скорости)' to 'Арена'.
30 July 2017, 19:45:39
logan219, changed speed limit from 60 to 90.
24 September 2017, 09:54:28
Dovos, changed speed limit from 90 to 60.
01 September 2018, 16:47:26
Timon34, changed object latitude from 45.817974 to 45.818141
Timon34, changed object longitude from 51.664447 to 51.664046
Timon34, changed warning direction from 348 to 349.
Timon34, changed object notification distance from 500 to 450.
Timon34, changed object description from 'Арена' to 'Кречет '.
01 September 2018, 17:05:49
Timon34, changed object latitude from 45.818141 to 45.817974
Timon34, changed object longitude from 51.664046 to 51.664447
Timon34, changed object description from 'Кречет ' to 'Арена'.
01 September 2018, 17:07:06
Откатил настройки обратно. В штрафе https://mapcam.info/speedcam/point.php?idx=1001818#comment_2159452 оказались кривые координаты, а судя по картинке, камера все-таки, висит уже в Энгельсе (возможно, раньше висела здесь)
10 August 2019, 15:07:37
10 August 2019, 15:07:49
10 August 2019, 15:08:10
Не знаю что за камера. Но думаю что не Арена.
10 August 2019, 15:10:46
Это метео. Для водителей не опасна.
10 August 2019, 16:01:21
Timon34, changed object description from 'Арена' to 'Метео'.
10 August 2019, 16:01:33
В ноль -1
10 August 2019, 16:01:39
В ноль -1
10 August 2019, 16:01:46
В ноль -1
09 September 2019, 17:18:06
Моё предложение автору убрать совсем. Таких камер на трассах сотни, не вижу смысла обозначать лишь единицы из них. На удаление.
12 September 2019, 13:17:43
Удаляю
