22 October 2026, 02:58:42
Кордон-М2
Russian Federation > Брянская область
13 April 2014, 17:16:32
04 August 2014, 19:00:12
ignat-78, changed speed limit from 50 to 60.
ignat-78, confirmed object added via Mapcam.info program
23 September 2014, 16:24:17
если контроль был в обе стороны - разбейте на 2 точки, пожалуйста.
23 September 2014, 16:24:41
radiorecordperm, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Мобильная камера (засада)'.
23 December 2014, 11:30:10
DiK57, changed warning direction from 252 to 248.
DiK57, changed object notification distance from 500 to 300.
DiK57, changed object view angle from 15 to 20.
02 August 2015, 21:26:35
Получил штраф ограничение там 60 км, камера сняла в попутном направлении (со спины фото). Координаты:N53.134600, E34.137448, Брянская область, 21 км 400 м а/д Брянск-Новозыбков, Выгоничский райнон. Судя по снимку мобильная камера  у меня указан КРИС П FP2720 +1
15 September 2015, 06:34:24
DiK57, changed object latitude from 34.131644 to 34.137555
DiK57, changed object longitude from 53.133249 to 53.134484
DiK57, changed object type from  Portable Camera (trap) Portable Camera (trap) to  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!).
14 November 2015, 00:12:36
могут и за обгон штрафонуть
25 April 2016, 09:07:22
КРИС-П, 60 км/ч
КРИС-П, 60 км/ч
27 April 2016, 10:38:52
16 July 2016, 19:51:56
20 September 2016, 02:29:11
NightWatcher, changed object latitude from 34.137555 to 34.134771
NightWatcher, changed object longitude from 53.134484 to 53.133879
NightWatcher, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to  Static speed camera Static speed camera.
NightWatcher, changed warning direction type from Two directions to In a certain direction.
NightWatcher, changed warning direction from 248 to 70.
NightWatcher, changed object notification distance from 300 to 400.
NightWatcher, changed object description from 'Мобильная камера (засада)' to 'Кордон-М2'.
20 September 2016, 02:31:30
Кордон, 60 км/ч
Кордон, 60 км/ч
21 September 2016, 01:11:25
Как будто камера на опоре, но сам обращал внимание на это место(см. фото 2016-07-16, 22:51:56) - нет там таких камер, возможно на тот момент и не было.
20 September 2016, 02:32:02
21 September 2016, 01:15:07
Судя по снимкам штрафов это мобильная камера, её периодически ставят с гражданской машиной прикрытия.
21 September 2016, 06:34:14
Верхние снимки похожи на треногу или ящик, а вот последнее нет.
21 September 2016, 19:42:28
направление: Гомель-Брянск
21 September 2016, 20:05:00
Возможное расположение камеры
21 September 2016, 20:25:04
Порылся в своём старом видеоархиве и нашёл где всё-таки эта камера висит
21 September 2016, 20:26:04
так для общего понимания картины_1
21 September 2016, 20:26:24
о понимания картины_2
21 September 2016, 20:26:56
так для общего понимания картины_3
21 September 2016, 20:27:35
и вот сама камера
и вот сама камера
21 September 2016, 20:28:14
с привязкой к карте
с привязкой к карте
21 September 2016, 20:34:57
А вот от 2016.07.24 18-27-02
21 September 2016, 20:43:15
и ещё одна общая картинка
03 February 2017, 17:45:58
08 August 2017, 17:58:17
Кордон, 60 км/ч
Кордон, 60 км/ч
20 January 2018, 13:14:09
22 May 2018, 11:41:22
DiK57, changed camera model.
01 June 2018, 13:38:20
Кордон функционирует. +1
19 January 2020, 13:09:17
semaa1, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
19 January 2020, 13:09:30
Многоцелевой фоторадарный комплекс "КОРДОН-М"2 MD0191 [ul] [li]Нарушение скоростного режима[/li] [li]Выезд и (или) движение по встречной полосе, тротуару, обочине, пешеходной или велосипедной дорожке, нарушения движений по полосам[/li] [/ul]
19 January 2020, 14:02:35
19 January 2020, 14:35:50
14 August 2020, 06:33:48
14 August 2020, 06:35:13
DiK57, changed object type from  Traffic control complex Traffic control complex to  Static speed camera Static speed camera.
14 August 2020, 07:10:47
Кордон в этой точке помимо скорости также вполне успешно контролирует выезд на встречную полосу через сплошную разделительную линию.
28 May 2021, 15:42:00
Камера работает +1
19 August 2024, 10:21:26
Демотнировали -1
19 August 2024, 10:21:30
Демотнировали -1
19 August 2024, 10:21:33
Демотнировали -1
19 August 2024, 12:07:51
См выше -1
19 August 2024, 12:07:55
См выше -1
19 August 2024, 12:07:59
См выше -1
19 August 2024, 13:15:23
19 August 2024, 13:15:32
19 August 2024, 13:16:47
19 August 2024, 17:27:57
Попросьбе. Демонтаж -1
19 August 2024, 17:28:03
19 August 2024, 18:09:35
По просьбе выше -1
19 August 2024, 18:09:40
По просьбе выше -1
19 August 2024, 19:24:56
Ком выше -1
19 August 2024, 19:25:01
Ком выше -1
19 August 2024, 19:25:12
Ком выше -1
