22 October 2026, 08:14:00
Другая опасность
Ukraine > Полтавська область
23 November 2012, 20:36:32
23 November 2012, 20:37:06
съезд на новую полосу
17 February 2013, 01:28:26
Max_rl, changed object latitude from 33.498226 to 33.499117
Max_rl, changed object longitude from 49.680657 to 49.680518
Max_rl, changed object type from  Dangerous change of direction Dangerous change of direction to  Other danger Other danger.
Max_rl, changed warning direction from 103 to 283.
Max_rl, changed object notification distance from 500 to 361.
Max_rl, changed object description from 'Опасное изменение направления движения' to 'Другая опасность'.
20 February 2013, 22:40:15
Max_rl, changed object latitude from 33.499117 to 33.499417
Max_rl, changed object longitude from 49.680518 to 49.680480
Max_rl, changed warning direction from 283 to 102.
24 February 2013, 18:49:39
Max_rl, changed object latitude from 33.499417 to 33.499353
Max_rl, changed object longitude from 49.680480 to 49.680494
Max_rl, changed warning direction from 102 to 283.
24 February 2013, 18:50:10
Max_rl, changed warning direction from 283 to 104.
31 July 2021, 08:36:34
На удаление! Уже не актуальна.
31 July 2021, 08:37:06
Не актуальна. -1
31 July 2021, 08:37:10
Не актуальна. -1
31 July 2021, 08:37:12
Не актуальна. -1
26 August 2021, 08:04:33
См.выше. Удалил. -1
26 August 2021, 08:04:35
См.выше. Удалил. -1
26 August 2021, 08:04:37
См.выше. Удалил. -1
