22 October 2026, 08:51:37
демонтаж
21 November 2020, 17:21:46
21 November 2020, 18:25:44
intruder197, changed object latitude from 37.799016 to 37.798921
intruder197, changed object longitude from 55.844796 to 55.845120
intruder197, changed speed limit from 90 to 100.
intruder197, changed speed limit from 0 to 100.
intruder197, changed warning direction type from Two directions to In a certain direction.
intruder197, changed warning direction from 312 to 133.
intruder197, changed object notification distance from 500 to 250.
intruder197, changed object description from 'Объект добавлен 2020-11-21 17:22:38 с помощью MapcamDroid' to 'Sova'.
intruder197, confirmed object added via Mapcam.info program
intruder197, changed camera model.
22 November 2020, 03:30:28
intruder197, switched object to test mode
22 November 2020, 16:46:46
intruder197, turned off test mode
23 November 2020, 05:36:27
23 November 2020, 16:04:29
intruder197, changed object notification distance from 250 to 200.
23 November 2020, 16:09:41
intruder197, changed object description from 'Sova' to 'Стрелка-360-С'.
10 December 2020, 13:48:58
Рано срадатывает, камера на столбе прям около табли 100-й км, когда камеру проезжаешь до объекта показывает еще метро 60
10 December 2020, 15:47:30
Точка установлена в конец участка контроля. Камера фиксирует в лоб или спину, смотря куда смотрит
10 December 2020, 15:49:49
Понял, а известен ли регламент в какую сторону она смотрит? Или теперь это лотерея?
10 December 2020, 15:52:06
Лотерея, объектив вращается
14 December 2020, 18:04:46
balabol.1974, changed object latitude from 37.798921 to 37.799806
balabol.1974, changed object longitude from 55.845120 to 55.844684
balabol.1974, changed object description from 'Стрелка-360-С' to 'Стрелка-360-С (фронт/тыл)'.
14 December 2020, 18:06:59
balabol.1974, changed object notification distance from 200 to 250.
29 January 2021, 17:47:51
29 January 2021, 17:48:26
29 January 2021, 17:48:46
29 January 2021, 17:48:51
19 March 2021, 12:10:12
08 June 2021, 03:52:56
08 June 2021, 03:54:10
intruder197, changed object description from 'Стрелка-360-С (фронт/тыл)' to 'Стрелка-360-С (фронт/тыл) [100км]'.
15 January 2022, 19:31:20
balabol.1974, changed object description from 'Стрелка-360-С (фронт/тыл) [100км]' to 'Стрелка-360-С [100км]'.
15 January 2022, 19:35:49
balabol.1974, changed object notification distance from 250 to 350.
30 January 2022, 17:31:44
balabol.1974, changed control direction from Counter direction to Both directions.
07 October 2022, 04:17:10
15 February 2024, 14:10:22
, changed object description from 'Стрелка-360-С [100км]' to 'демонтаж'.
15 February 2024, 14:10:34
ДЕМОНТАЖ -1
15 February 2024, 14:10:36
ДЕМОНТАЖ -1
15 February 2024, 14:10:38
ДЕМОНТАЖ -1
15 February 2024, 18:01:32
выше -1
15 February 2024, 18:01:35
выше -1
15 February 2024, 18:01:38
выше -1
15 February 2024, 18:02:13
, changed object type from  Lane Control Camera Lane Control Camera to  Dangerous cross-road Dangerous cross-road.
15 February 2024, 18:02:40
, changed object type from  Dangerous cross-road Dangerous cross-road to  Other danger Other danger.
