22 October 2026, 05:46:32
Камера в спину
29 June 2019, 17:36:06
29 June 2019, 17:41:54
antiradar_086, changed control area.
antiradar_086, changed object type from   to   .
antiradar_086, changed speed limit from 70 to 90.
antiradar_086, changed speed limit from 0 to 70.
antiradar_086, changed warning direction type from Two directions to In a certain direction.
antiradar_086, changed warning direction from 300 to 296.
antiradar_086, changed object notification distance from 500 to 700.
antiradar_086, changed object view angle from 15 to 25.
antiradar_086, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Камера в спину'.
antiradar_086, confirmed object added via Mapcam.info program
29 June 2019, 18:59:05
29 June 2019, 19:01:01
Timon34, changed warning direction from 296 to 298.
Timon34, changed object notification distance from 700 to 500.
Timon34, changed object view angle from 25 to 20.
30 August 2020, 12:54:30
Gold76, changed object latitude from 62.728288 to 62.727071
Gold76, changed object longitude from 56.874760 to 56.875111
Gold76, changed control area.
30 August 2020, 13:06:30
Timon34, changed object latitude from 62.727071 to 62.727049
Timon34, changed object longitude from 56.875111 to 56.875108
30 August 2020, 13:09:51
Немного передвинул, чтобы точки в лоб и в спину полностью не накладывались друг на друга на общей карте. Большие сомнения, что Арена работает в оба направления, но пока не понятно в каком направлении она осуществляет фиксацию
19 August 2021, 14:25:57
Камеру убрали. Реконструкция дороги. Точка не актуальна!
29 July 2022, 15:52:26
Демонтирована -1
29 July 2022, 15:52:29
Демонтирована -1
29 July 2022, 15:52:32
Демонтирована -1
29 July 2022, 16:25:02
29 July 2022, 16:25:09
29 July 2022, 16:25:17
