05 November 2026, 03:17:51
Стрелка-Плюс (тыл)
25 August 2011, 06:03:02
25 August 2011, 07:24:47
The-x-demon, changed object latitude from 37.497800 to 37.497875
The-x-demon, changed object longitude from 55.773201 to 55.773228
25 August 2011, 07:25:19
спасибо, поправил
25 August 2011, 07:41:28
Заяц, changed object latitude from 37.497875 to 37.497902
Заяц, changed object longitude from 55.773228 to 55.773237
Заяц, changed warning direction from 143 to 142.
Заяц, changed object notification distance from 100 to 150.
12 July 2012, 08:05:29
Все еще актуально ?
19 October 2013, 15:17:44
S.Седой, changed object view angle from 10 to 15.
12 March 2018, 04:08:59
Спам. -1
12 March 2018, 06:16:53
Выше -1
12 March 2018, 06:17:11
Ashkrmane, changed object type from  Bad road ahead Bad road ahead to  Other danger Other danger.
Ashkrmane, changed object notification distance from 150 to 100.
Ashkrmane, changed object view angle from 15 to 10.
Ashkrmane, changed object description from 'Плохая дорога' to 'спам'.
10 September 2018, 12:46:29
, changed object latitude from 37.497902 to 37.500648
, changed object longitude from 55.773238 to 55.782699
10 September 2018, 12:46:37
, changed object latitude from 37.500648 to 37.500305
, changed object longitude from 55.782699 to 55.793412
10 September 2018, 12:46:49
, changed object latitude from 37.500305 to 37.504253
, changed object longitude from 55.793412 to 55.803254
10 September 2018, 12:49:33
, changed object latitude from 37.504253 to 37.512397
, changed object longitude from 55.803254 to 55.805311
, changed object type from  Other danger Other danger to   .
, changed speed limit from 10 to 60.
, changed warning direction from 142 to 293.
, changed object notification distance from 100 to 200.
, changed object description from 'спам' to 'Стрелка-СТ (тыл)'.
10 September 2018, 12:50:57
Парная точка к соседней. - https://mapcam.info/speedcam/point.php?idx=1076837 +1
10 September 2018, 12:52:58
"Хвост" не требуется, точка отмечена в конце зоны контроля.
10 September 2018, 12:54:44
, changed object notification distance from 200 to 250.
14 September 2018, 08:22:16
видимо надо поднять до 1 +1
22 September 2018, 14:41:34
22 September 2018, 14:42:23
Подтверждено штрафом! +1
22 September 2018, 14:42:48
22 September 2018, 14:42:52
22 September 2018, 16:16:45
работает. Сегодня утром проверил.
22 September 2018, 16:19:55
вот как то так
вот как то так
22 September 2018, 17:15:03
Спасибо и + за фото
22 September 2018, 17:15:23
Подтверждено штрафами, актуально для мото +1
22 September 2018, 17:15:34
Подтверждено штрафами, актуально для грузовиков +1
23 September 2018, 18:15:07
Подтверждено штрафом. Только не понятно - фотографирует машину сзади, а на карте камера указана переда разворотом. +1
23 September 2018, 18:26:07
Читать здесь https://mapcam.info/speedcam/point.php?idx=157859#comment_2166662
23 September 2018, 21:05:20
23 September 2018, 21:09:49
27 September 2018, 07:59:01
Тоже попал на эту камеру, совсем недавно поставили!
04 October 2018, 08:07:50
04 October 2018, 08:07:55
15 October 2018, 07:48:33
15 October 2018, 13:24:35
Спросил получателя этого штрафа, как же это он так поехал, ведь явное нарушение же? Ответ: "Так вел яндекс-навигатор, иначе перестроиться в левый ряд для разворота было невозможно". Не оправдываю нарушителя, но это, ИМХО, явный косяк маршрута в навигаторе.
16 October 2018, 13:33:59
На дублере ясно знаками указано, что разворот только из левого ряда.
22 October 2018, 10:17:38
21 October 2018, 07:04:06
26 October 2018, 05:12:24
Прилетело: штраф по ч.1 ст.12.16 КРФоАП - 500 руб.
01 November 2018, 18:32:28
04 November 2018, 09:08:22
fiat14, changed object type from   to  Lane Control Camera Lane Control Camera.
04 November 2018, 09:09:01
причина - точка без хвоста
07 November 2018, 11:46:10
13 November 2018, 13:16:19
02 March 2019, 15:09:31
11 March 2019, 07:47:07
20 March 2019, 11:17:33
25 July 2019, 20:40:48
03 September 2019, 17:16:59
23 September 2019, 06:52:19
20 October 2019, 11:11:12
Штраф за размеку +1
21 November 2019, 10:37:53
10 February 2020, 05:27:32
Hyundi505, changed warning direction from 293 to 291.
10 February 2020, 05:28:53
Убрал с Ленинградского тоннеля
21 February 2020, 18:59:49
maykl3011, changed object notification distance from 250 to 120.
maykl3011, changed object view angle from 15 to 20.
21 February 2020, 19:00:34
Сократил до соседней камеры, см.общую карту.
08 April 2020, 01:12:41
31 May 2020, 12:54:41
об этой камере работает предупреждение при проезде в тоннеле в сторону центра Ленинградского проспекта, что не правильно.
31 May 2020, 13:03:35
Уменьшил угол, чтобы не фонило.
31 May 2020, 13:01:31
setpiton, changed object view angle from 20 to 15.
31 May 2020, 13:05:55
setpiton, changed object notification distance from 120 to 130.
26 June 2020, 07:19:50
12 September 2020, 17:50:48
30 June 2021, 22:13:14
Не надо ли сдвинуть эту камеру ближе к области? Судя по фото с неё она стоит на углу дома, метров за 50 до той точки, где она сейчас отмечена.
30 June 2021, 22:13:25
30 June 2021, 22:20:28
18 July 2021, 13:26:12
заменили на Стрелку V.2
18 July 2021, 13:28:53
18 July 2021, 13:30:30
abbc, changed camera model.
18 July 2021, 13:32:54
abbc, changed object description from 'Стрелка-СТ (тыл)' to 'Стрелка-Плюс V.2 (тыл)'.
05 August 2021, 12:38:02
daniyar.sariev, changed object description from 'Стрелка-Плюс V.2 (тыл)' to 'Стрелка-Плюс (тыл)'.
14 September 2021, 14:32:16
До рейтинга плюс 1. Замена комплекса -1
14 September 2021, 14:32:20
15 September 2021, 11:07:48
Выше. -1
15 September 2021, 11:07:52
Выше. -1
15 September 2021, 11:07:56
Выше. -1
05 November 2021, 20:36:52
balabol.1974, changed object latitude from 37.512397 to 37.510911
balabol.1974, changed object longitude from 55.805311 to 55.805744
balabol.1974, changed object type from  Lane Control Camera Lane Control Camera to   .
balabol.1974, changed warning direction from 291 to 288.
balabol.1974, changed object notification distance from 130 to 200.
05 November 2021, 20:40:45
balabol.1974, changed object latitude from 37.510911 to 37.511982
balabol.1974, changed object longitude from 55.805744 to 55.805455
balabol.1974, changed object type from   to  Other danger Other danger.
05 November 2021, 20:41:48
balabol.1974, changed object type from  Other danger Other danger to  Lane Control Camera Lane Control Camera.
balabol.1974, changed object notification distance from 200 to 250.
05 November 2021, 20:44:00
05 November 2021, 20:44:26
актуально +1
05 November 2021, 20:44:30
актуально +1
05 November 2021, 20:44:34
актуально +1
05 November 2021, 20:55:24
balabol.1974, changed object notification distance from 250 to 300.
27 November 2021, 19:22:08
14 January 2022, 23:08:28
14 January 2022, 23:09:01
12.16.1 - Несоблюдение требований знаков или разметки.
29 November 2024, 19:55:57
29 November 2024, 19:56:34
Разметка. Штраф 250₽
15 January 2025, 19:20:30
, changed object latitude from 37.511982 to 37.510918
, changed object longitude from 55.805455 to 55.805729
, changed object notification distance from 300 to 150.
