31 October 2026, 05:32:37
камера контроля полосы для маршрутных ТС
16 September 2014, 09:56:18
15 October 2014, 05:41:59
Камера действительно есть, но не думаю, что нужно указывать такое большое расстояния для предупреждения. Метров 200-300 будет более чем достаточно. И по-моему (нужно проверить), она стоит чуть дальше по движению.
15 October 2014, 08:01:12
allexandr, changed object latitude from 38.986015 to 38.986294
allexandr, changed object longitude from 45.018840 to 45.018794
allexandr, changed warning direction from 283 to 278.
allexandr, changed object notification distance from 500 to 200.
allexandr, changed object view angle from 20 to 15.
28 October 2014, 05:55:29
"письма счастья" +1
28 October 2014, 05:55:30
"письма счастья"
29 July 2017, 12:35:49
29 July 2017, 12:36:01
Камеры на месте. На фото видна работа ИК-подсветки
30 July 2017, 16:12:56
silandser, changed warning direction from 278 to 275.
silandser, changed object notification distance from 200 to 300.
silandser, changed object view angle from 15 to 30.
15 August 2017, 09:19:56
silandser, changed object latitude from 38.986294 to 38.985632
silandser, changed object longitude from 45.018794 to 45.018885
15 August 2017, 09:20:23
Cкорректировал точку по GPS
silandser, changed object view angle from 30 to 40.
09 July 2024, 13:16:37
устарело?
31 July 2026, 21:39:36
31 July 2026, 21:39:40
31 July 2026, 21:39:42
31 July 2026, 21:42:41
29 August 2026, 13:01:15
29 August 2026, 13:01:19
29 August 2026, 13:01:22
29 August 2026, 13:01:53
, changed object view angle from 40 to 10.
29 August 2026, 17:36:31
29 August 2026, 17:36:33
29 August 2026, 17:36:37
