22 October 2026, 10:44:06
СКАТ-ПП (тыл)
27 April 2017, 06:13:53
27 April 2017, 10:55:23
action_64, changed object notification distance from 200 to 250.
17 August 2017, 17:21:44
Dovos, changed object latitude from 45.997428 to 45.996698
Dovos, changed object longitude from 51.568305 to 51.568910
28 September 2017, 08:10:16
Dovos, changed object latitude from 45.996698 to 45.996441
Dovos, changed object longitude from 51.568910 to 51.569110
Dovos, changed control area.
Dovos, changed object type from  Static speed camera Static speed camera to   .
Dovos, changed object description from 'Кордон М2' to 'Кордон-Темп'.
28 September 2017, 08:10:22
Фото
23 May 2018, 15:42:00
23 May 2018, 15:42:23
23 May 2018, 15:43:39
01 March 2020, 06:13:20
уже две недели назад передвинули камеру. теперь перед светофором на тулайкова. точно не знаю та же или нет
06 October 2020, 09:50:09
сняли -1
06 October 2020, 09:50:13
сняли -1
06 October 2020, 09:50:17
сняли -1
20 October 2020, 07:27:43
Камеры давно нет -1
20 October 2020, 07:27:48
Камеры давно нет -1
20 October 2020, 07:27:53
Камеры давно нет -1
03 December 2020, 11:10:28
по просьбе -1
03 December 2020, 11:10:32
по просьбе -1
03 December 2020, 11:10:35
по просьбе -1
18 June 2022, 07:42:03
Timon34, changed object latitude from 45.996441 to 45.996995
Timon34, changed object longitude from 51.569110 to 51.568688
Timon34, changed object description from 'Кордон-Темп' to 'СКАТ-ПП (тыл)'.
18 June 2022, 07:42:39
Timon34, changed warning direction from 141 to 142.
Timon34, changed object notification distance from 250 to 200.
18 June 2022, 07:43:13
На зеркалах в спину https://yandex.ru/maps/-/CCUJnRHOCC
18 June 2022, 07:44:09
Актуализация +1
18 June 2022, 07:44:21
Актуализация +1
18 June 2022, 07:44:33
Актуализация +1
18 June 2022, 07:44:52
Просьба поднять рейтинг точке до положительного. Установлен СКАТ-ПП
18 June 2022, 08:38:17
Актуализировал, см выше +1
18 June 2022, 08:38:20
18 June 2022, 08:38:23
14 October 2022, 13:20:37
Есть у кого-нибудь инфа. ,что камера будет фиксировать не пристегнутый ремень?
14 October 2022, 15:25:36
Во-первых, точка в спину никак не может фиксировать ремни. Во-вторых, пока со СКАТов не видел ни единого подобного штрафа, но прогресс не стоит на месте. За ремни (и не только) обилечивают Стрелки (модель с дополнительным раструбом), Пульсары, АвтоУраган-ВСМ-2, Трафик-Сканер-СМ2, возможно Кордоны, мог что-то еще сразу не вспомнить
18 October 2022, 17:11:20
Встречное направление камеры! В спину - это уже устарелая информация!
18 October 2022, 17:11:21
19 October 2022, 06:05:05
На зеркалах все без изменений - в этом направлении в спину. Физически, камера одна, опоры тоже с одной стороны. Для направления в лоб есть отдельная точка в лоб https://mapcam.info/speedcam/point.php?idm=2RD0YYtCseE
19 October 2022, 12:32:53
Без каких изменений? Зеркала старые. Теоретически невозможно.
19 October 2022, 16:12:54
Практически невозможно. Опоры есть только с одного направления. Судя по скану штрафа, который выложил коллега, камера висит точно также как и раньше, иначе ракурс на фото был бы с противоположного края автомобиля при движении в лоб. Если проезжаете там регулярно, выложите свежее фото камеры на местности, поскольку сейчас свежих зеркал не будет для основной массы регионов в связи с определенными событиями (но уверен, что никаких изменений там нет исходя из пояснений выше и скана штрафа). Ну и минус Вам прилетел НЕ от меня.
19 October 2022, 12:32:54
16 October 2022, 08:59:59
19 October 2022, 06:05:41
Ваш штраф из парной точки в лоб https://mapcam.info/speedcam/point.php?idm=2RD0YYtCseE Просьба выложить его туда
19 October 2022, 08:58:33
Готово. А как теперь отсюда удалить?..
19 October 2022, 16:15:15
Никак, пусть остается. Спасибо и плюс Вам за скан штрафа. Это первый скан штрафа за ремень со СКАТа (других пока своими глазами не видел, но мог что-то пропустить). Судя по тенденции, в Саратовской области теперь надо взять за правило пристегиваться, поскольку у Вас и других типов камер, которые обилечивают за ремни очень много
19 October 2022, 20:03:44
"Казна пустеет милорд! Нужно больше золота!" К сожалению, сейчас так везде и, в основном, к повышению уровня безопасности дорожного движения всё это имеет довольно слабое отношение.
