22 October 2026, 13:25:24
18 April 2018, 07:19:50
18 April 2018, 07:23:29
Alex_190, changed object latitude from 38.668630 to 38.668641
Alex_190, changed object longitude from 55.802281 to 55.802257
Alex_190, changed object type from   to  Static speed camera Static speed camera.
Alex_190, changed speed limit from 30 to 60.
Alex_190, changed warning direction type from Two directions to In a certain direction.
Alex_190, changed warning direction from 83 to 253.
Alex_190, changed object notification distance from 500 to 350.
Alex_190, changed object view angle from 15 to 30.
Alex_190, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'АвтоУраган-ВСМ-2'.
Alex_190, confirmed object added via Mapcam.info program
18 April 2018, 07:31:25
АвтоУраган-ВСМ-2
АвтоУраган-ВСМ-2
18 April 2018, 07:32:57
Судя по всему работает. Блок снизу светится красным.
18 April 2018, 11:25:53
Спасибо.
29 May 2018, 14:45:17
10 August 2018, 10:07:41
10 August 2018, 10:08:44
10 August 2018, 10:12:00
zhuk668, changed object latitude from 38.668641 to 38.668280
zhuk668, changed object longitude from 55.802257 to 55.802220
10 August 2018, 10:12:57
Подправил по GPS координатам.
10 August 2018, 10:31:01
03 October 2018, 17:19:17
03 October 2018, 18:04:21
28 October 2018, 09:05:55
18 January 2019, 12:05:10
, changed object description from 'АвтоУраган-ВСМ-2' to 'АвтоУраган-ВСМ-2 (1км 000м)'.
30 November 2020, 13:03:35
30 November 2020, 13:04:07
Ashkrmane, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
06 May 2021, 18:05:59
Замена на муляж. -1
06 May 2021, 18:06:18
Замена на муляж. -1
06 May 2021, 18:08:03
zhuk668, changed object type from  Traffic control complex Traffic control complex to  Static speed camera Static speed camera.
zhuk668, changed object description from 'АвтоУраган-ВСМ-2 (1км 000м)' to 'МУЛЯЖ! АвтоУраган (рейтинг ноль)'.
zhuk668, changed camera model.
zhuk668, changed additional information (RU): \"
06 May 2021, 18:13:19
Повесили муляж.
06 May 2021, 18:23:35
По просьбе, до 0 -1
06 May 2021, 18:23:41
По просьбе, до 0 -1
20 May 2026, 05:44:21
, changed object latitude from 38.668280 to 38.668280
, changed object longitude from 55.802220 to 55.802244
, changed warning direction from 253 to 71.
