22 October 2026, 02:58:38
демонтаж
Russian Federation > Республика Дагестан
28 September 2013, 18:48:12
28 September 2013, 19:00:32
denverit, changed warning direction from 70 to 257.
29 September 2013, 17:32:34
denverit, changed object description from 'Камера с радаром на столбе' to 'Камера, измеряющая скорость, Кордон.'.
20 October 2014, 12:04:08
Определяется радар-детектором Supra iGV-68VST
20 October 2014, 12:04:09
20 October 2014, 12:04:12
20 October 2014, 12:04:14
Определяется радар-детектором Supra iGV-68VST +1
28 October 2014, 09:07:23
Там действительно стоит камера и радар на нее реагирует
04 February 2015, 13:07:50
DiK57, changed warning direction from 257 to 253.
04 February 2015, 13:08:33
DiK57, changed object view angle from 15 to 20.
02 February 2016, 07:38:13
SlikKo, changed object description from 'Камера, измеряющая скорость, Кордон.' to 'КОРДОН'.
10 January 2017, 16:45:19
10 January 2017, 16:45:33
штрафует +1
11 January 2017, 17:51:26
MVV23RUS, changed control area.
MVV23RUS, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
11 January 2017, 19:28:40
ZoSo, changed control area.
ZoSo, changed speed limit from 60 to 40.
12 January 2017, 17:08:13
uDAV163, changed object type from  Traffic control complex Traffic control complex to  Static speed camera Static speed camera.
19 August 2024, 21:54:01
, changed object description from 'КОРДОН' to 'демонтаж'.
19 August 2024, 21:54:14
19 August 2024, 21:54:16
19 August 2024, 21:54:18
19 August 2024, 21:55:48
демонтаж, столб пуст, у гаишников нет  2018   2024
20 August 2024, 04:44:53
Отсутствует -1
20 August 2024, 04:44:57
Отсутствует -1
20 August 2024, 04:44:59
Отсутствует -1
20 August 2024, 04:58:36
поддерживаю, на удаление -1
20 August 2024, 04:59:03
см. ввше, на удаление -1
20 August 2024, 04:59:18
см. выше, на удаление -1
20 August 2024, 05:28:44
20 August 2024, 05:28:47
20 August 2024, 05:28:49
