23 October 2026, 05:52:44
ОСКОН или СКАТ-П [25км 720м]
03 February 2020, 14:33:46
03 February 2020, 14:43:28
DarkMatter, changed object notification distance from 450 to 500.
03 February 2020, 15:03:20
DarkMatter, changed speed limit from 60 to 90.
DarkMatter, changed speed limit from 60 to 70.
03 February 2020, 19:01:51
Подтверждаю,стоял сегодня
03 February 2020, 20:50:48
04 February 2020, 18:50:59
04 February 2020, 18:52:23
04 February 2020, 18:53:15
  ДПСка стояла
04 February 2020, 18:57:42
16 February 2020, 06:51:52
RedLight, changed speed limit from 90 to 40.
RedLight, changed speed limit from 70 to 40.
17 February 2020, 09:24:23
fantompg, changed object description from 'ОСКОН' to 'ОСКОН [25км 720м]'.
17 February 2020, 09:25:02
17 February 2020, 09:25:14
подтверждено +1
17 February 2020, 09:25:16
подтверждено +1
25 February 2020, 12:24:08
25 February 2020, 12:24:24
28 February 2020, 01:28:12
спасибо, плюс
04 March 2020, 16:53:28
04 March 2020, 16:53:56
04 March 2020, 16:56:03
setpiton, changed object view angle from 20 to 25.
06 March 2020, 19:27:25
Подтверждено 2020-03-06 13:27:05 (UTC±00:00)
     Вероятность: 94 %  (Частота за прошлый месяц)
08 March 2020, 20:39:40
 Прилетело за 29 февраля.
18 March 2020, 15:54:07
01 April 2020, 15:17:07
09 April 2020, 12:56:16
13 April 2020, 08:19:38
16 April 2020, 07:54:12
16 April 2020, 07:54:56
Ограничение 40 км/ч
17 April 2020, 08:16:15
03 May 2020, 18:53:41
05 May 2020, 08:08:52
05 May 2020, 09:35:15
08 May 2020, 04:33:28
19 May 2020, 15:50:00
19 May 2020, 15:50:28
Вот такая сегодня замечена.
19 May 2020, 21:18:26
19 May 2020, 21:19:04
19 May 2020, 23:00:15
DarkMatter, changed object description from 'ОСКОН [25км 720м]' to 'ОСКОН или СКАТ-П [25км 720м]'.
19 May 2020, 23:03:57
08 June 2020, 19:29:05
18 August 2020, 09:34:35
Видел в воскресенье камеру , которая стояла через 100м (после выезда). Комплекс был размешен на легковом автомобиле ( не знаю как называется). Добавьте в оповещение ("Возможна вторая камера через 100 метров"). Я не умею.
18 August 2020, 09:42:54
Добавил Вам в карму плюс один. Теперь при редактировании точки сможете добавить соответсвующую информацию к точке. Это работает при карме  плюс 20 и выше
18 August 2020, 09:44:16
18 August 2020, 09:45:32
bimko, changed camera model.
bimko, changed additional information (RU): \"
20 August 2020, 09:41:35
svelles, changed object latitude from 37.929289 to 37.927562
svelles, changed object longitude from 55.634592 to 55.635737
svelles, changed warning direction from 128 to 137.
svelles, changed object notification distance from 500 to 600.
20 August 2020, 09:42:28
Переехала точка
20 August 2020, 09:42:58
Фото ниже
20 August 2020, 09:42:42
29 August 2020, 23:08:56
29 August 2020, 23:09:34
29 August 2020, 23:13:12
Постановление оформлено 28.08.20. Как вот эту траекторию понимать?
31 August 2020, 12:24:03
DarkMatter, changed object description from 'ОСКОН или СКАТ-П [25км 720м]' to 'СКАТ-П [25км 720м]'.
31 August 2020, 12:24:28
Для мото хорошо бы 0
31 August 2020, 12:45:12
По просьбе автора точки -1
09 November 2020, 08:54:02
09 November 2020, 08:55:15
Ashkrmane, changed object description from 'СКАТ-П [25км 720м]' to 'СКАТ-П [25км 600м]'.
27 November 2020, 16:14:33
на  "зеркалах" от 24.11.20 г.
07 February 2021, 10:44:54
Gheka, changed object latitude from 37.927562 to 37.929061
Gheka, changed object longitude from 55.635737 to 55.634803
Gheka, changed warning direction from 137 to 134.
24 March 2021, 20:35:01
DarkMatter, changed object description from 'СКАТ-П [25км 600м]' to 'ОСКОН или СКАТ-П [25км 600м]'.
24 April 2021, 05:39:48
02 May 2021, 00:44:07
DarkMatter, changed object description from 'ОСКОН или СКАТ-П [25км 600м]' to 'ОСКОН или СКАТ-П [25км 720м]'.
04 May 2021, 14:25:09
27 August 2021, 13:44:51
Давно не вижу ее на этом месте
08 November 2021, 08:51:04
Этого места уже давно нет!
08 November 2021, 12:34:49
DarkMatter, switched object to test mode
09 November 2021, 20:17:42
Выше -1
09 November 2021, 20:17:47
Выше -1
09 November 2021, 20:17:50
Выше -1
10 November 2021, 11:15:42
По просьбе выше -1
10 November 2021, 11:15:48
По просьбе выше -1
10 November 2021, 11:15:58
По просьбе выше -1
10 November 2021, 14:32:30
ну коли уверены, что не будет более, то на удаление
