25 June 2026, 04:08:16
For the past 24 hours: 97 objects added, 77 objects edited, 19 objects removed.
КРИС-П в боксе
18 August 2020, 06:30:30
18 August 2020, 09:56:04
Alsanat, changed object latitude from 34.415171 to 34.415349
Alsanat, changed object longitude from 63.284096 to 63.284085
Alsanat, changed object type from   to  Static speed camera Static speed camera.
Alsanat, changed speed limit from 0 to 90.
Alsanat, changed warning direction type from Two directions to In a certain direction.
Alsanat, changed warning direction from 358 to 10.
Alsanat, changed object notification distance from 500 to 497.
Alsanat, changed object view angle from 15 to 10.
Alsanat, confirmed object added via Mapcam.info program
18 August 2020, 09:59:01
Alsanat, changed object notification distance from 497 to 500.
18 August 2020, 10:01:12
Alsanat, changed object notification distance from 500 to 600.
Alsanat, changed object view angle from 10 to 15.
18 August 2020, 20:39:29
oleinap, changed speed limit from 90 to 70.
29 September 2020, 19:34:30
oleinap, changed object latitude from 34.415349 to 34.415499
oleinap, changed object longitude from 63.284085 to 63.284619
oleinap, changed object description from 'Объект добавлен 2020-08-17 07:19:24 с помощью MapcamDroid' to 'Камера'.
oleinap, changed camera model.
29 September 2020, 19:37:20
Стационарная или передвижная, проверьте пожалуйста
29 September 2020, 20:08:07
стационарная, обычный КРИС в ящике
29 September 2020, 20:13:39
а точнее ящик под камеру, в который устанавливают КРИС-П. Когда ехал - не работал, то есть там камеры не было. Но ящик нужно отметить, бо лучше снизить скорость перед пустым ящиком, чем пролететь работающую камеру
13 October 2020, 19:50:22
oleinap, changed object description from 'Камера' to 'КРИС-П в боксе'.
08 July 2021, 20:06:43
отсутствует, проехал-проверил -1
08 July 2021, 20:06:45
08 July 2021, 20:06:48
20 August 2021, 15:49:15
Отсутствует -1
20 August 2021, 15:49:21
Отсутствует -1
20 August 2021, 15:49:26
Отсутствует -1
