22 October 2026, 03:52:07
КОРДОН-М 2 (в спину)
13 December 2013, 11:31:52
06 February 2014, 01:37:21
тат, changed object latitude from 32.979779 to 32.979618
тат, changed object longitude from 68.994987 to 68.994968
тат, changed speed limit from 60 to 70.
тат, changed object notification distance from 500 to 300.
тат, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Ограничения скорости 70 км/ч'.
тат, confirmed object added via Mapcam.info program
18 February 2015, 19:20:35
sademid51, changed object description from 'Ограничения скорости 70 км/ч' to 'Ограничения скорости 70'.
16 November 2023, 18:20:14
sademid51, changed object latitude from 32.979618 to 32.972094
sademid51, changed object longitude from 68.994968 to 68.999340
sademid51, changed object type from  Speed limit sign Speed limit sign to  Integrated camera Integrated camera.
sademid51, changed speed limit from 70 to 90.
sademid51, changed warning direction from 163 to 143.
sademid51, changed control direction from Counter direction to In the back.
sademid51, changed object notification distance from 300 to 400.
sademid51, changed object view angle from 15 to 55.
sademid51, changed object description from 'Ограничения скорости 70' to 'Ящик под камеру (в спину)'.
sademid51, changed camera model.
24 February 2024, 19:56:11
, changed object type from  Integrated camera Integrated camera to  Static speed camera Static speed camera.
, changed object description from 'Ящик под камеру (в спину)' to 'стационарная камера (в спину)'.
24 February 2024, 20:11:47
, changed object description from 'стационарная камера (в спину)' to 'КОРДОН-М 2 (в спину)'.
18 March 2024, 12:44:11
, changed object latitude from 32.972094 to 32.972274
, changed object longitude from 68.999340 to 68.999222
, changed warning direction from 143 to 331.
, changed object view angle from 55 to 25.
18 March 2024, 12:44:30
, changed object latitude from 32.972274 to 32.972107
, changed object longitude from 68.999222 to 68.999320
23 September 2024, 18:33:02
23 September 2024, 18:33:05
23 September 2024, 18:33:07
17 October 2024, 16:52:22
См. выше -1
17 October 2024, 16:52:25
См. выше -1
17 October 2024, 16:52:27
См. выше -1
