22 October 2026, 06:52:28
Антивандальный ящик
30 August 2015, 06:19:56
30 August 2015, 06:25:25
svirydov, changed object latitude from 132.967873 to 132.969847
svirydov, changed object longitude from 48.766882 to 48.768466
svirydov, changed warning direction from 241 to 224.
svirydov, changed object notification distance from 328 to 338.
svirydov, changed object view angle from 15 to 28.
30 August 2015, 07:51:49
deksven_dair, changed object view angle from 28 to 30.
deksven_dair, changed object description from 'стационарный ящик в который часто ставят камеру работает в одном направлении' to 'Ящик для камеры'.
30 August 2015, 07:52:19
Описание пишем кратко, некоторые программы выводят его на экран.
30 August 2015, 08:37:43
feudor10, changed object latitude from 132.969847 to 132.969906
feudor10, changed object longitude from 48.768466 to 48.768431
feudor10, changed warning direction from 224 to 229.
31 August 2015, 04:48:17
Предупреждение лучше выставить на оба направления, камера снимает и перед и зад авто
16 February 2017, 09:03:32
yuryleb, changed warning direction type from In a certain direction to Two directions.
yuryleb, changed warning start time from 16 to 8.
yuryleb, changed warning end time from 17 to 18.
10 May 2017, 15:30:29
Почему ограничение по времени? У меня радардетектора нет, но мне и ночью моргали, предупреждая о камере.
10 May 2017, 15:28:07
10 May 2017, 15:30:33
07 August 2017, 04:56:13
filaret, changed object description from 'Ящик для камеры' to 'КРИС-П'.
filaret, changed warning start time from 8 to 0.
filaret, changed warning end time from 18 to 24.
20 August 2017, 11:04:42
filaret, changed object latitude from 132.969906 to 132.969165
filaret, changed object longitude from 48.768431 to 48.767966
15 October 2017, 02:38:07
filaret, changed warning direction type from Two directions to In a certain direction.
filaret, changed object notification distance from 338 to 400.
15 October 2017, 02:41:16
Дубль к http://mapcam.info/speedcam/point.php?idx=1031273
14 August 2018, 23:28:49
Давно не используется -1
25 March 2019, 07:17:35
24.03.2019 внутри антивандального ящика появился КРИС-П, но РД на него не реагировал.
25 March 2019, 07:18:18
Стоит КРИС-П +1
25 March 2019, 07:18:23
Стоит КРИС-П +1
25 March 2019, 07:20:39
filaret, changed object description from 'КРИС-П' to 'Антивандальный ящик'.
29 March 2020, 08:02:21
uDAV163, changed object latitude from 132.969165 to 132.969242
uDAV163, changed object longitude from 48.767966 to 48.767960
uDAV163, changed object type from  Static speed camera Static speed camera to  Integrated camera Integrated camera.
09 February 2022, 04:12:04
filaret, changed control area.
filaret, changed control direction from Counter direction to In the back.
08 July 2024, 01:42:51
, changed object latitude from 132.969242 to 132.970580
, changed object longitude from 48.767960 to 48.768860
04 March 2025, 00:07:28
камеру убрали -1
04 March 2025, 00:07:31
камеру убрали -1
04 March 2025, 00:09:31
, changed object type from  Integrated camera Integrated camera to  Other danger Other danger.
04 March 2025, 02:57:55
1.7 Запрещается менять параметры объекта на заведомо несуществующие независимо от рейтинга объекта.
04 March 2025, 03:02:33
В прошлом году в Хабаровске по Тихоокеанской поменяли таким образом несколько моих точек.
04 March 2025, 03:03:52
Нарушили правила. Вам то зачем за ними повторять и нарушать правила тоже?
04 March 2025, 03:05:23
Нет, я не помнил или не знал этого правила и добросовестно заблуждался, делая по аналогии. Я просто объяснил, почему так поступил.
04 March 2025, 00:46:59
см. выше -1
04 March 2025, 00:47:01
см. выше -1
04 March 2025, 00:47:02
см. выше -1
04 March 2025, 02:58:19
, changed object type from  Other danger Other danger to  Integrated camera Integrated camera.
