22 October 2026, 09:32:28
Ограничение скорости
11 November 2015, 08:09:28
11 November 2015, 08:10:36
Sgt_Scott, changed warning direction from 196 to 199.
Sgt_Scott, changed object notification distance from 165 to 200.
Sgt_Scott, changed object view angle from 31 to 24.
11 November 2015, 10:13:57
silandser, changed object latitude from 36.316917 to 36.316863
silandser, changed warning direction from 199 to 196.
silandser, changed object notification distance from 200 to 170.
silandser, changed object view angle from 24 to 25.
11 November 2015, 10:14:21
Углы желательно ставить кратно 5 градусам.
15 July 2019, 21:06:47
Знак ограничения скорости отсутствует, просьба к автору удалить точку -1
15 July 2019, 21:08:23
см. выше,   вернул -1
15 July 2019, 21:19:28
плюс вернул
15 July 2019, 21:09:18
см. выше -1
23 July 2019, 15:11:05
smirnof, changed object latitude from 36.316863 to 36.316851
smirnof, changed object longitude from 55.386565 to 55.386644
smirnof, changed warning direction from 196 to 15.
smirnof, changed object notification distance from 170 to 279.
smirnof, changed object view angle from 25 to 15.
23 July 2019, 15:30:51
smirnof, changed object notification distance from 279 to 250.
25 July 2019, 16:50:48
25 July 2019, 16:50:56
smirnof, changed object latitude from 36.316851 to 36.316860
smirnof, changed object longitude from 55.386644 to 55.386646
smirnof, changed object notification distance from 250 to 300.
25 July 2019, 16:51:58
Редактирование точки +1
25 July 2019, 16:52:19
25 July 2019, 16:57:25
см. выше +1
24 May 2020, 18:18:51
Знак убрали -1
24 May 2020, 18:19:10
См. выше -1
24 May 2020, 18:19:15
См. выше -1
27 May 2020, 14:23:07
18 June 2021, 16:08:58
см выше, удалил -1
18 June 2021, 16:09:01
см выше, удалил -1
18 June 2021, 16:09:04
см выше, удалил -1
